SL/R230: Started wrapping my car in Satin White Pearl
Old May 3, 2018 | 09:31 PM
FxFormat's Avatar
SL 600
Though my paint is in immaculate condition, I decided to wrap it anyways. Will be the exact same vinyl i used on my Land Cruiser so the'll be matching. lol
I do it right by removing every panel that comes out, so it's a cleaner look around the edges than wrapping it on the car like most shops do. I can take pretty much any part off, so if you need help removing a part of the car, let me know and i'll guide you through it.
Vinyl is Avery Denisson Supreme Satin white pearl. I bought 40 feet of it, at $8 a foot. Plenty for this car
With my real camera the color will look like this, i just finished the hood, fenders, and side skirts. will work on it some more on sunday.
Old May 3, 2018 | 11:03 PM
Ariesfamous's Avatar
2015 cls550
Nice. I'm gonna watch..
Keep posting pics please
Old May 3, 2018 | 11:17 PM
Bahnstormer's Avatar
2010 E63 AMG, 2003 E500
Beautiful sheen to it.
Old May 4, 2018 | 11:10 AM
SVTF-150's Avatar
Audi S4, SVT F-150 Lightning
this is going to look really fantastic when all is said and done!
Old May 7, 2018 | 05:06 PM
Hary Gahtoe's Avatar
R230, C5 Corvette Convertible, Audi Allroad, Lexus RX350, AE86 Hachi Roku
Removing panels doesnt improve quality of wraps and not practiced when done by trained pros. It’s around trim that make or break a good vinyl wrap. Shops don’t do it on Bentley’s or Ferrari’s because it’s just not any better and sets up for bad refitment and huge timelines.
Knowing the correct way set the vinyl, heat, shrink and proper use of knifeless tape will yield a higher level of finish than pulling off panels. Good applicators can work around headlights, taillights etc without removing them.
Dont forget even Satin Pearl White has “grain” to it and all panels must be placed in unison or the reflected light will show a color variance.
Doing bumpers in one single piece and mirrors are the hardest parts on any car
Good luck
Hary
Old May 7, 2018 | 08:43 PM
FxFormat's Avatar
SL 600
Got some more panels done today, all that's left to do is the front and rear bumpers and 1/4 panels, and mirrors. So 2 more days of wrapping then i'll be done.
Roof Trim, front rubber was super super tight, ended up removing the trim piece to tuck it down there.
Old May 7, 2018 | 09:11 PM
FxFormat's Avatar
SL 600
Good luck
Hary
I disagree, removing the parts to wrap around the edges gives it a much cleaner look and less prone to lifting. Cars such as the R230 have air tight gaps for the side skirts, front fenders/bumpers. If you don't remove it, there is no way to get complete coverage under the gap, i can hardly fit the wedge in there so tucking it without removing it was not an option. Would look very bad if someone were to bend down and look at the gap straight on. Shops don't like to remove stuff because it takes time, and time equals money, and the risk of them losing screws and misplacing things adds to that. That's why I wrap my own vehicles because i learn about it this way as well. A lot of work to remove panels but it's well worth it. The bumpers I will wrap with it on the car, but then i'll remove the parts where it meets the fenders and 1/4 panels to get complete coverage under there.
I did the same thing wrapping my land cruiser, removed anything that could be removed, much bigger vehicle and that turned out great, nobody knows it's wrapped unless i told them. Same vinyl Satin white pearl. The vinyl pieces were from a single roll with horizontal orientation with the print on the back upright all around the vehicle, hood and rear hatch was vertical.
Old May 8, 2018 | 08:59 AM
2015 cls550
Awesome work!
Look forward to seeing her finished.
Old May 8, 2018 | 11:17 AM
FxFormat's Avatar
SL 600
Originally Posted by Ariesfamous
Awesome work!
Thank you, i need 2 more full days to finish her. Then i'll take her to the mountains and take some pics with a real DSLR. This color is awesome during sunset, brings out the pearl really well.
Old May 9, 2018 | 03:25 AM
I salute individualism and applaud detail.
You have impeccable workmanship
If a shop were to work at this level chances are they’d cover the inner edge of the door skins, remove both doors to get the body structure behind the doors and do the underside of the hood and trunk to make the effect match the level of effort followed. But at that level of time you have to admit you’re edging to a point at where paint is almost the same effort but won’t change color while lasting 15-20 years more than vinyls possibly 3years before looking tired.
I did a pearl satin wrap a little over 3yrs ago. You can’t hide gravel or bug rash with a wrap. It starts to lift. Can’t be buffed out like paint scuffs either but does look very good new.
I have a good friend with a ATS-V in factory satin pearl white. Trust me from 20’ away you can tell paint from vinyl. Your cars look fabulous but no matter how you slice it, vinyl never matches paint but remains a secondary, cost effective alternative to paint.
Good Luck
Hary
Old May 9, 2018 | 08:20 AM
2015 cls550
Good luck
Hary
Good Luck
Hary
Ok. Your work here is done.. Bye Harry
Old May 9, 2018 | 03:17 PM
Good vinyl will be astonishing but in the end vinyl is merely a way to “stand out” instead of painting
Replies are respectful and adding a perspective you ^ don’t seem to understand or value others rights.
Last edited by Hary Gahtoe; May 9, 2018 at 07:15 PM. Reason: Disrespectful previous posting
Old May 9, 2018 | 03:27 PM
2015 cls550
Maybe your neighbors wife will be astonished but in the end vinyl is merely a cheap way to “stand out” instead of manning up and painting
Bon Chance Mon Ami
You should get a life. Guys like you are why this forum is dead..
Go away already, you add nothing to this thread.
Instead of bashing on this guy's wrap job go worry about your p.o.s sl.
Old May 14, 2018 | 09:48 PM
FxFormat's Avatar
SL 600
Got some more panels done today, got the rest of the trunk finish, what a pain to wrap. And both rear 1/4 panels done, also installed the face lifted rear bumper.
All the corners are nice and tight, removing the tail lights and rear bumper are major major pain in the ***. Pretty much gotta gut the interior trunk lining to get to the bolts.
I still have to wrap the bumpers but that'll have to be next day off, which is next saturday. I've been spending all my days off working on the car, i think the missus will take a hammer to it if i don't finish it soon and give her the attention she needs.
Old May 15, 2018 | 12:30 AM
57staff's Avatar
2008 CL550
Where did you get the SL65 rear bumper? Do you have Park Assist and if so, how easy was it to convert to the new bumper?
Looking good.
Old May 15, 2018 | 10:31 AM
FxFormat's Avatar
SL 600
Looking good.
This is not the authentic one, those costs like 2 grand and the used ones are broken and still asks for a grand, and then you'd have to get a diffuser as well so it's going to add up. I ended up biting the bullet and getting the Duraflex one, it fits like butthole and the amount of work to transfer the old brackets over to the new bumper took quite some time. Good thing i have body work experience and tons of tools at my disposal, it looks as thought it's OEM now. Lots of sanding, shaving, cutting. The bumper didn't have the original tabs to mount the bracket so you have to use counter sunk screws to secure the mounting plates on. Then you have to trim your panel underneath because it doesn't fit. If you're patient and know what you're doing, this bumper isn't bad after you put about half a day of work into it. Since i'm wrapping it, the vinyl adds strength to the overall finish, any stress fracture on the fiberglass won't be visible through vinyl as it would be with paint.
I do have park distance sensors, i don't think i've seen an R230 without one. I have to bore the holes for it and get new mounting brackets.
This is what i got https://www.ebay.com/itm/Duraflex-Mercedes-R230-Sl65-Look-Rear-Bumper-Body-Kit-1-Pc-For-Merced/291408070026?epid=1737634360&hash=item43d946458a:g :2kIAAOSwgJla91E4
Old May 26, 2018 | 06:13 PM
FxFormat's Avatar
SL 600
Got some new wheels for the car, these are forged and is lighter than what i had on before, and wider.
20x9F ET +25
255/30/20 Toyo Proxes T1R
20x10.5R ET+30
305/25/20 Toyo Proxes T1R
They stick out a little past the fender, but I don't think it'll rub, looks awesome though.
Old May 30, 2018 | 09:52 AM
FxFormat's Avatar
SL 600
Car is just about done, now all that's left is to trim all the vinyl and touch up whatever is needed. Still gotta put all the fender liners and bottom covers back on.
Old May 30, 2018 | 10:18 AM
2015 cls550
Oh hell ya.
Looks great!
Old May 30, 2018 | 12:01 PM
Fantastic work - you're the kind of guy I'd want working on my car at a shop - meticulous as hell.
Old May 30, 2018 | 12:48 PM
FxFormat's Avatar
SL 600
Thanks guys, wrapping isn't all that hard, just time consuming. I've got 40 hours into this job, i could do it quicker if i didn't remove all the panels, but i want it done right so i'm taking my time.
Old May 30, 2018 | 04:58 PM
TheFranchizeSLB's Avatar
2014 Mercedes Benz CLS 550
wow that looks amazing!!!! that amount of patience and attention to detail is definitely admirable!
Old May 31, 2018 | 02:40 PM
Noir230's Avatar
1992 400E, 1997 SL500, 2007 SL55 AMG, 2016 E400
That really looks great. Well done!
Being unfamiliar with wrapping, my only questions are how do you go about washing the car and do you wax it? Do you have to use a special soap or wax?
Old May 31, 2018 | 05:42 PM
SGTzAMG's Avatar
Veteran: Army
02 C32 AMG, 05 SL55 AMG, 09 SL63 AMG, 14 E350, '18 G550, 92 300ZX & 15' GL63 AMG
WOW!
Old May 31, 2018 | 08:01 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
Amazing job. Love it.
