SL/R230: ABC Pump replacement broken bolt
My questions are... Is this true? Is there normally one bolt holding the ABC pump on? Do I have any recourse?
I bought this car about 7 months ago and have had nothing but problems. I've put 3K miles on it and almost 10K into it this is after the 19.5K I paid for the car originally.
TRUTH... I was really taken wasn't I? I've replaced a coil pack, the Valve Block (front), and just chased engine codes. Had to get a waiver because this car would not pass emissions.
Thanks Scott
Do you have any recourse? Small claims court maybe? It's a used car, not much you can do at this point.
That being said, since you bought it so long ago, you may be SOL unless the car spent more time in the shop than on the road...
That said. The place I have it now has been able to remove the bolt from the block and mounted the ABC pump correctly. German Motors in Golden Colorado is the bomb. (does anyone use that term anymore?)
The mechanic working for my seller couldn't bother with that.
Let me know if anyone interested in this seller. He sells a lot of Mercedes out of Pennsylvania. Don't get burned. Thanks Scott
At this point, it's just bad luck but you can't do much about a 14 year old car you bought used other than complain online. You can fix it and keep it, or try to sell it back for what you paid for it, but there is little else.
Seriously, I'm glad it's fixed. Broken bolts are really not the end of the world, There are tools like EZ-Out extractors and HeliCoils for damaged threads. My advice to you is to not stress over paying too much for the car. You obviously thought it was a good deal when you bought it, so just give it the maintenance it needs and enjoy driving it.
The problem was that the bolt was not in an easy location to drill out. My mechanic had to fabricate something to insure he drilled straight down the bolt.
I'll never get outta it what I have in it at this point... It is a kick to drive when it's working.
