SL/R230: Unwanted Downshift to manual mode, unable to shift up or down.
It usually happens after 15 to 20 minutes of driving. It will shift, on its own, to first, second, third or fourth depending on speed. Most of the time I can shift my way back to drive, other times it appears to be in limp and I have to park it. After clearing the issue by upshifting to drive or parking the car it often happens again almost immediately. I cleared codes before I drove it, rechecked after the failure and found nothing I checked every module.
Any ideas to further diagnose are welcome. For me a dealer STARS scan is a last resort but so far that's looking like the best option.
He thinks this could cause the transmission issue, but after describing issues with the paddle shifters he thinks it could be Transmission Condule Module (TCM) or a Shift Module.
My ICarsoft doesn't report any issue with the TCM. So I have 2 questions if any can answer:
1. It seems like a stretch to think the passenger SAM could be the issue. Further, why would the passenger side SAM impede communication with the TCM? Will replacing have any chance of changing anything? Wouldn't I see other electrical issues with a bad SAM?
2. Dealer says cost is $900. I've read DYI is possible has anyone replaced one of these before? It doesn't seem too difficult and I don't believe it requires coding. I might just buy a rebuild or send mine for rebuild and install it myself. But again, I am skeptical this is going to change anything.
Thanks.
I just checked the module with icarsoft and it cant even read it just crashes the scanner. Drivers side sam reports no communication tho.
Already called dealer to repair, thanks I agree I think sam is culprit here I wish I had paid more attention to this module on the initial scan.
There may be hacks to get around the need for obtaining an SCN from a dealer or other professional service -- I don't know -- it's been thoroughly discussed on the *******.com forums.
There are services which will provide an SCN for a one-time fee. Here is one doing business on aliexpress.com which charges $34 per session: https://www.aliexpress.com/item/Onli...881832045.html.
A drawback of the iCarsoft 980 and perhaps your MB II as well is that you have to address and then query each module individually to check for faults. In a particular case where one is unsure what systems may have a role in a problem being diagnosed, reading codes from as many as 30-odd modules can be tedious and time consuming. In contrast Star Diagnosis automates all of this via its "Quick test" and presents a concise summary of the results.
New trunk battery also drained again this time while on the tender. I think its SAM related. So the direction I'm heading now is that SAM is entire problem causing both battery and shifting failure. Can't wait to fix it!
https://www.benzworld.org/forums/r23...ownshifts.html
I'm so confident it's the steering module that I'm done troubleshooting. I'm going to instruct dealer to just replace it. If anyone can provide the Part # for 2009 550SL that would be great so I make sure the right module gets done. If DIY makes sense let me know. Thanks in advance.
1. Car downshifts at random, this could be because the steering module thinks it's getting a signal (false) from the down shift paddle.
2. When the problem occurs, using the upshift paddle causes a downshift. The downshift paddle is not operational.
3. The console shift will usually work and get you back to drive, but not always. Sometimes you have to stop and go to Park.
This was a tough one to figure out, I got lucky stumbling on an old post.
I too now have the same problem on my 2009 SL550. I’ll be driving and it will automatically go into manual mode and start downshifting. I was even on the highway doing 60mph and it started downshifting all the way into 2nd! Had I not caught it in time it would have gone into 1st and I would have probably over revved the engine!
Now that I found this thread and the older thread on the other forum, it seems like I have to replace the steering column module. In the other thread in the other forum he mentioned that the steering column module was tied into the air bag. Was that the case in yours? Did you also have to replace the airbag?
im hoping I can find a used steering column module but I’m not sure if they are vin locked. Would I be able to use a home based Star diagnostic to reprogram this or would a stop at the dealership be required?
In reading your symptoms all of mine are the same except that my downshift paddle works fine. The upshfit paddle does not. You mentioned that when you hit the up shift that the car actually downshifts for you. Also when this happens to me, especially while driving I can shift into neutral and then back to drive in order for it to get out of manual mode and back in the drive mode. I do not have to stop and go into park to reset the shifting.
