SL/R230: 2003 SL500 various issues
I've done some searching on the forum for some advice on issues I'm facing. The cars a 2003 SL500 it's been standing for around 6 months unused. It has approx 87k miles on it. I just wanted anyones thoughts on these as I'm about to buy it to replace my Vette.
Issues are:
Push start not working - either switch or wiring maybe damaged in the knob as the car starts with the key in the ignition. Is there anything else it could be.
Slight misfire but no code - got me stumped no idea on this one. Dont really want to try to drive it in case I get worse issues. It doesn't have much fuel so I'm hoping its either just low or dirty. Anything else it could be?
P0705 transmission code - guessing it's the electronic controller. The car shifts into drive and reverse. No idea if it will go through the gears as I dont want to drive it due to the above.
SRS warning - Batteries have died and been charged so maybe its needing to be reset But the front bumper was cracked after hitting a kerb so no idea if it's a faulty sensor but no codes.
Roof not operating - It just beeps and says service required. I'm told this is likely due to the transmission issue. Any advice?
Any advice would be very much welcomed.
In case anyone would wonder why someone would buy such a car. The suspension has been changed to coilovers, the brakes are great, Body and interior are mint and I dont mind mechanical or electrical issues when buying as the issues will be negotiated from the price.
Thanks,
Craig.
The explanation they gave was if the transmission system has a fault it could stop the roof from operating as it may think it's in gear and travelling. But I have zero experience beyond 80s and 90s Mercs.
that just presented itself on my 04 SL55 (72k miles all stock ) and I was able to clear the code a couple times and car drove normally but it’s come back and clearly something is wrong.
car drives and goes into reverse but won’t shift out of 1st gear or reverse.
I had this on my w203/c32 and it was about 1000 to have the shifter mechanism replaced since the electronics quit…will check the trans connector to see if it’s leaking fluid and try to clean that up as a last attempt…..
any others feedback on this would be super appreciated.
