SL/R230: Current leak @ ABC control valve.
I used DAS to check the condition of ABC valve. My rear left current value is different from other 3 side. Without turning valve on, other 3 sides current value =0mA, while my rear left control valve current read 9.8mA. Pls see the screen. Is it normal? Can I continue to use? Or there is something wrong with rear left solenoid control valve. Please suggest. Thanks.
DAS screen, read 9.8mA current @control valve, which are 0mA for front right, front left and rear right.
I make a point of not commenting on suggestions made in other posts unless I believe they would be a needless waste of significant time or money. That is the case here, as I do not recommend checking the electrical connector of the control valve in search for a cause of this non-zero current.
