SL/R230: ABC Reservoir Overflowing After Fluid Exchange-Air? How?
The second mechanic specializes in Mercedes and I trust their work. He said it could be the accumulator which is the same thing the first Mechanic told me but he told me he would have to open it up to check by inserting a stick or something into the accumulator to see if it’s bad.
another member of this form said you can check to see if your accumulators are bad using SDS. If this is possible I’m not sure why my mechanic did not do this. We both decided to leave it alone since everything is working properly and no error codes are being returned. He said let’s not throw parts at it and just wait
I should probably check to be certain before typing this -- I'm sure you need Star Diagnosis to change the accumulators or pulsation dampener. And I don't think you I don't think it's possible to screw something up.
In a day or two I'll be replacing an accumulator on a car that was manufactured in 2002. It has 127,000 miles, and likely all accumulators and pulsation dampener are original. So contrary to a popular belief, these components generally last considerably longer than 10 years or 50,000 miles.
On a 2005 car I personally would only replace the accumulator which has failed. If you do not know which one that is, then guess; if you guess right your done, otherwise you replace the other accumulator. And since I presume your don't hear sounds coming from the left-side engine compartment with the engine between 2000 and 3000 RPMs, then I would leave the pulsation dampener alone. Cost of the repair with this advice if you do it yourself: c. $100-$200.
I've replaced a hose, filter, fluid, all the accumulators and the pulsation damper, and worked on the valve blocks without any major disaster. If you can do basic maintenance (and it sounds like you can), I’d go for it. You will need the right tools! Don’t half *** it and round off or strip a fitting using the wrong tools.
Start with doing the pulsation damper and if all goes well, tackle the other bits. Replace your alarm siren while you’re in there.
With that being said, life was good for me after replacing the accumulators and pulsation damper without using SDS/rodeo. However, I really caused problems when I changed the fluid which must have dislodged particles that caused my valve blocks to malfunction...and is still not 100% resolved as the front of my car still sags slightly while the car is parked. I’ve rebuilt valve blocks, I’ve even replaced one valve block with a new OEM one $$$, I bought an SDS and have done tons of troubleshooting and rodeos, even had another fluid flush and filter change performed by one of the most reputable Benz Indy shops in all of Southern California....and I’m still worse off than when I bought the car with a seemingly untouched ABC system at the end of last year.
This isn’t my first old german car, I replaced the pulsation damper and accumulators right after I bought it as preventative maintenance to help prevent ruptured hoses, nothing was actually wrong.
So, based on my experience I bet you will be fine replacing these parts, even without an SDS system. I also believe that it is necessary to preserve the life of the other components by changing the fluid...but doing so might open a massive can of worms. If your car survived the fluid change without issue, you’re probably in good shape.
