SL/R230: Front left strut quick disconnect stuck
Old Oct 3, 2021 | 06:20 PM
Ohmann's Avatar
2003 SL500 1991 190E 2.3 2011 ML350 1998 SL500
Ladies and gentlemen
Replacing third strut (front left) 2003 sl500 130k miles
Quick disconnect Stuck. Will Not move to release hose
Has anyone had this problem?.
Any suggestions or experience with this problem
would be greatly appreciated?
Old Oct 3, 2021 | 11:48 PM
sivikvtec's Avatar
2005 SL65 AMG
Did you open the bleeder valve to relieve pressure off the line?
Old Oct 4, 2021 | 07:40 AM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
Spray it down good with some penetrating oil, start by turning the collar back and forth with pliers and then try to get some forward and back travel. Keep spraying and working it, you will get it eventually.
Old Oct 4, 2021 | 08:11 AM
Ohmann's Avatar
Yes
I have relieved the pressure at the tab
soaking it with nut buster stuff
removed hose at the strut to take it out for more room to work
trying to gently move the release up and down to unstick it with large offset pliers
to no avail
i have sprayed it morning and night for days
On YouTube there is a shop that sells a tool that attaches to release and slides it with pressure applied turning bolt against the 90 degree turn
Will order that if it doesn’t move soon
Thank You
Forum Rocks
Old Oct 4, 2021 | 05:39 PM
sivikvtec's Avatar
2005 SL65 AMG
But did you open the bleeder valve on the line, or did you unscrew the line for that strut from the front valve block?
You need to drain the fluid from the line that’s connecting that strut before separating the quick disconnect.
Old Oct 4, 2021 | 07:32 PM
Ohmann's Avatar
The bleeder valve I bled is one that is sitting in the line It has a rubber cover
removed and replaced
Will look at strut tomorrow afternoon
It sure feels like there is pressure as it will not move
i can undo line at valve block to be sure
Thank You
Old Oct 5, 2021 | 12:56 AM
sivikvtec's Avatar
2005 SL65 AMG
If you opened the bleeder and fluid came out, I wouldn’t worry about disconnecting the line at the valve block. I guess the quick disconnect is just seized up.
Old Oct 5, 2021 | 08:43 AM
Ohmann's Avatar
I’m afraid your right
All the work is worth it
Like having two cars
one with the top up and another when it’s in the trunk
I will get it done
Thank You
Old Oct 9, 2021 | 04:11 PM
cdk4219's Avatar
95 SL600
It’s rusted, just lightly grab the collar with a medium size vise grip and rotate back snd forth while pushing or pulling in the direction of release. I had 3 that were corroded and needed attention. I also had a second set of vise grips to hold the hose while I was rotating the collar. It took the stubborn one about 5 minutes snd it popped off.
Kind of a silly fitting to put on a car, when a nice JIC style fitting would do and work well IMO.
Old Oct 10, 2021 | 03:26 PM
Astro14's Avatar
Veteran: Navy
2005 S600 2005 SL600
I've had the same challenge. I've done a few struts on my S600. Same fitting, different strut.
Not certain which "nut buster" you're using...
I am a fan of Kano Lab's "Kroil" penetrating oil. WD-40 is terrible in that application. PB'laster is hyped junk. Liquid Wrench isn't bad.
A good shot of the penetrating oil - soak the inside of the fitting, and work it slowly back and forth (rotate around the line) and that will free it up eventually.
Old Oct 10, 2021 | 06:13 PM
Ohmann's Avatar
Yes using pb blaster
was finally able to move the sleeve up and down with vise grips after it broke free
Still will not slide
i will try your penetrate
determined to move that bugger
Need to be cautious
Holding main line with 19mm wrench
I’m 72 so don’t have as much upper body strength as I used to have
i am patient
I’ll outsmart it
thanks to all for your experience
Old Oct 10, 2021 | 07:28 PM
cdk4219's Avatar
95 SL600
Vise grips not too tight to bend sleeve. Rotate Bach and forth while spraying with lube and then rotate snd push towards the release.
Old Oct 13, 2021 | 05:58 PM
Ohmann's Avatar
Update
Really could not move quick disconnect
What I ended up doing was disconnecting hose at the strut
Removed new hose from Arnott replacement
Attached old hose to new strut
Realize this is not the best way to go
Next time I have the car in my AutoHaus repair shop for something I cannot repair I’ll have the hose replaced at this strut
For now back to flying through Va Beach mostly with the top down
in a month or so convertible weather will be on hold for 3/4 months
Thanks to all for your help
Together we know so much more
Old Oct 14, 2021 | 02:09 PM
Astro14's Avatar
Veteran: Navy
Wait, you’re in Virginia Beach? I missed that.
Send me a PM. You’re welcome to bring it by my shop. We can get it squared away.
