SL/R230: Car not starting - bad battery or bad starter?
Both batteries were replaced back in 2017, so they are not new.
When parked in the garage for more than a few days, the rear battery is always connected to a CTEK maintainer. The car always starts like a champ, but I do get the red battery warning light for an unknown to me reason with every start. The red light became very consistent over the last 5-6 months.
Both batteries show to be charging well when the car runs. I tested both with a battery tester a month ago and they both were healthy.
About 3 weeks ago, I tried to start the car, and it barely started and then died - it was cranking well, but it was sputtering, almost felt like it was not getting enough fuel and cutting off. I tried to start it 3-4 times, and it acted the same way. I was 95% sure it was a fuel related issue. On the 5th time, it started just like normal, as if nothing happened earlier. I drove it around, and it felt like it was a bit down on power at first (a bit sluggish), but then it went back to normal with full power. No issues. I restarted the engine again and all was good. I blamed it on "bad gas" or some dirt in the fuel (my fuel filter is 1 yr old btw) and moved on. I parked it in the garage and did not investigate further.
Since we went on 2-week vacation, I completely disconnected the rear battery while we were gone. I connected the battery today, tried to start the car, and it hesitated to start the first time again !! On the second try - it was all good. Started with no obvious hesitation. I drove it around the neighborhood for 5-6 minutes, parked in the garage and turned it off. Decided to start it, and now I get just a single click and no start. The dashboard lights come on, i can lower the windows, change gears, stereo comes on, so it all gets power, but I can only here ONE click from under the hood. No engine cranking at all. I moved the gear selector to "N" from "P" - it made no difference. No movement or attempts from the engine to start at all. Just a 'click'.
So the big question now is - do I have a bad battery or is this something else, like a failed starter?
If a battery - which of the two batteries do I suspect?
If not a battery - is this how a starter normally fails? It gives me just one "click"? No other noises, errors, etc?
If not a starter or battery - what else could it be?
Thank you in advance for any tips and suggestions!
Could be the ignition switch itself, intermittently failing to pass signal to fuel, ignition, and/or the starter.
If you're going to DIY on any Mercedes, you really need to have some kind of OBDII code reader at bare minimum. It's very likely there's some information stored in your car's computer that'll tell you what's going on.
Check the stickys at the top of this forum for a thread on one of the better cheap solutions. Or if you're up to spend 600-700 you can get a fully functioning Xentry system, same as the MB dealers have, which has diagnostics, Workshop Information System (repair procedures), and Electronic Parts Catalog. If you want to go this route, I'd recommend you contact BenzNinja. There's cheaper Xentry clones you can get from China, but they often lock up and can't be recovered, and they have -0- support after the sale.
First I plugged my old C3 STAR scanner and one of the few faults stored was under the BNS module, and it stated "B1832 - Component G1/4 (Starter Battery) is defective"
Since I was not convinced, I found my NocoGenius jump starter, connected it to the front battery, and after the second try, the car started perfectly normal. I let it run for 5 min. Disconnected the jump starter, turned off the engine - it could not start again. I am getting the single click again. Clearly, battery is bad. It's an OEM battery, not too old, but I guess it's time for a new one.
I will try to get a non-OEM battery tomorrow from a local parts store, and hopefully this will be the solution to my starting issue and the persistent red battery warning light I've been getting lately.
Thanks for all the input!
I checked with a voltmeter if the new battery was charging, and surprisingly it was not. It was showing 12.4V with the car running. Rear battery shows 14.5V.
This is very bizarre because about a month ago, I did check the front battery, and it was charging just fine. Something clearly changed.
So, I went on a mission to check the fuses under the passenger side foot well. With some moderate effort, I got to the fuses, (what a fun location) and sure enough, one of them, the smaller, 100amp fuse, was burned. How and why that happened, I have no idea? Did it happen because i "jumped" the car with my NOCO Genius car jumper 2 days ago? Or was it just old age? I mean, a 100amp fuse is pretty beefy, it can't just go bad for no reason.
Now I am waiting for the replacement fuse to arrive from Amazon and I hope that it will fix all my battery related issues.
The bad news - the Red Battery light still shows up on the dash when i start the car!!
I reset the fault with my STAR and it still comes back, saying it's either a "faulty K57 relay or no circuit 61"The relay was replaced, and the fuse is confirmed new now.
WHY does this keep happening?
Where is this red light coming from? Could it be the rear battery being old (it's 5 yrs old) and causing the issue? My understanding is that the red battery warning light is related to the front battery, not the rear.I am out of ideas at this point.
Even reading your first post brought me down memory lane until the red light stayed there permanently.
I haven't got into the footwell yet for that fuse- but it sounds like you did and that didn't fix it
Only 1 thing left is the BCM.
After the fuse replacement - both batteries are charging now, no issues with that. So it fixed the charging issue.
But the damn red battery warning light is still there, with the same error I have been getting for months now. The new fuse made no difference.
I took out the BCM out a couple of months ago to inspect it, since some people reported corrosion with these modules, fires, etc. My BCM looks like new inside. Everything is clean and shiny. No rust, no stains, no leaks, no visibly bad components.
I just ordered another brand new, OEM relay. I know that these things are pretty universal, but the last new one I got was colored black, and the old OEM I had was gray color. So, i am hoping, it was just the wrong relay and the new OEM relay will fix the issue.
Other than that .... what is really "circuit 61" ? Isn't that the same circuit with the blown 100amp fuse i just replaced?
Now I have 2 new batteries, front and rear, they both charge fine when the car is running, yet the red battery warning comes on every time I start the car. I reset the code and it comes back.
The interesting part is that the K57 relay next to the BCM is always warm. If car is off...relay is warm. If car is on, relay is still warm. I replaced the relay - no change. This means the K57 is staying closed/energized, and the only time this should happen is IF the system is in 'emergency' mode. There is no reason for the charging system to be in 'emergency' mode given that both of my batteries are new, alternator is good, fuses are good, and both batteries charge fine. This leaves the BCM being bad. I ordered a new one (close to $700) so once it arrives, it better fix the problem.
I was able to start it up after I had the modules reset in like 10 minutes time, but since then I have not been able to clear the system since I don’t have access. (And apparently there is something different that the STAR does that iCarSoft v.3.0 can’t perform)
You have used a maintance charger and you still have the red battery light lit up even with new batteries?
