SL/R230: Running abc suspension daily in 2024?
I'm looking for a new daily and want something that gives me that special feeling before I'm being forced into some electric eco box. I've always wanted a late model r129 or an r230 sl500. Late model r129 in Sweden are to expensive for a nice one, about the equivalent of 40k usd. A nice early model r230 can be had for around the equivalent of 20k usd.
Does anyone today run their r230 with abc suspension as a daily? What's that like? Have it worked out or just been a pain?
I'm mechanically inclined and very familiar with Mercedes from that time so my only real concern is the abc suspension. I have no problem with careful maintenance, replacing an strut or line here and there but have no interest in total failure or long down time since I do about 19k miles a year.
How sensitive is the abc suspension to ageing? I'm thinking to be safe, I need to find a car which at least once during it's lifetime would have more or less all abc components replaced to keep me from having to deal with total failure just due to age when I put the car to work. Is this correct or am I overcautious?
Sl350 is also and option but might be lacking a little in the power department. Yet another option is scraping the sl idea just getting a 2011-12 e350 cab for similar price as a early sl500. Opinions?
I had two airmatic cars before and as you say they were easy to maintain but they were a little hit or miss. My higher mileage e500 went on without any issues during my ownership while my mint, low mileage cls55 blew all for corners third day of ownership.
How long have you owned your car, what milage and what issues have you had?
<snip>
How sensitive is the abc suspension to ageing? I'm thinking to be safe, I need to find a car which at least once during it's lifetime would have more or less all abc components replaced to keep me from having to deal with total failure just due to age when I put the car to work. Is this correct or am I overcautious? <snip>
I have had a 2005 R230 since new and always dealer serviced at the selling dealer. I have been told that the ABC pumps start having issues at about 50,000 miles and my experience confirms that. My ABC pump failed internally at just about 50,000 miles. It was during the Covid transportation debacle and no ABC pumps were available through the dealer, anywhere in the US or from MBZ in Germany. I sourced a rebuilt pump from a German company that specializes in rebuilding ABC pumps and have had no issues since then. Good luck on your search.
Had it about two years with no ABC issues, other than replace badly perished front strut bellows (I think it is important to keep the struts clean and dirt free).
However I am very weary of corrosion of the steel pipework, which is now evident in a few places.
So next years task will be to replace as much of the pipework as practically possible, and survey the rest to see if it is essential to do or not.
If you can keep the fluid in, then I don't think there is much else to worry about.. :-) ..I am on original pump and struts after 100,000 miles, though I understand the previous owner had the rear valve block refurbished.
Dealership wanted NINE thousand dollars to replace that hose. HA. Indy shop #1 said they could do it for $5000. I found some engineers with their own car shop, called them up. "Sure we have done about ten of those, we'll do yours for $2000. Told them I had accumulators, pulsation damper, plus new motor mounts and trans mount in trunk, they said "We'll install all that for another $1000." Less than 24 hours after they received the car it was all done and ready, with all new ABC fluid and filter as well. Perfect ever since. I have no fear of ABC on these cars. You just need to know some competent mechanics who are nice people and honest, I know in today's world that is a tall order. I always shop online for genuine MBZ parts at the best prices, for any parts I need. All repairs done on my cars are done very cost effectively, without me getting ripped off by crooks. Be smart! Then the R230 is the best car you'll get for the money....
Then there is little chance that the system will fail and strand you. Change the gas cells when they fail. If you can DIY then the costs are modest.
There is no comparison between the R129 and the R230. The 129 is a slow noisy antique by comparison, with scuttle shake you'll hate. The R230 is so quiet and cosy with the roof down and the widows up.
@tonylinc What hoes did the want 9000 for? Sounds like one should be able to replace the entire system for that money.
@Tom Manning which are the gas cells you referring to?
How common is problems with parts actually bursting leaving one stranded? Identifying and replacing parts is fine. Regular towing not so much. I'm under the impression that one should not drive if the car lower itself due to a leak.
Any opinions on the 350? I drove one about 10 years ago. It felt really slow. I rarely drive very fast I cars these days but the engine must suit the car.
An increasing likelihood with age, but regular inspection may help identify trouble spots. We're talking about 20 year old hoses here which really all should be replaced.
I guess I should say I've lived with the ABC system on my S55 for over 15years. The car never saw daily driving duty though, except maybe during the summer (self employed, driving optional, etc). But it's a fairly basic system. At this point, all the fluid, filters and accumulators should be changed if you can't prove they have been already. On your car, it's the hydraulic top that keeps people up at night, in addition to the suspension.
Cheers,
maw
It's called a car killer hose in some circles due to that cost to replace, some folks give up and give the car away. If your accumulators are worn out they will not absorb shock and the system typically runs near 3000 PSI so you hit a bump, pressures can spike to much higher than that. When my accumulators were bad, there were warnings on the dash in red, "ABC, See workshop", and the car did not ride right, it was rough. I had bought new accumulators and pulsation damper, plus a new ABC filter and Pentosin fluid, that was all in the trunk along with new motor mounts and tranny mount. I was waiting to decide where to have all that installed but still driving around twice a week because, well, it's hard having an SL55 and not driving it. LoL. Should have just had all those installed but I hit a bump and the pressure was too much for that hi pressure hose. I was lucky to find another shop owned by those engineer brothers who did it ALL for under $3000. I'm happy now because that hose is I think, the one that takes the most pressure so, the first to go, and with all those new parts plus a new hose I think it's gonna be trouble free for a long time again.
I bought it because of the ABC, not despite it (and of course because of the engine). My son has a R230 with the 3.7 liter engine without ABC. That doesn't make the car that slow, but it really lacks everything that makes a R230 what it is. The car is not driven over the winter, the picture shows the difference in vehicle height after 6 months.
