SL/R230: WTB: 2009 SL550 - Rear wheel / Left Side - Inner fender liner
Thank you,
/John.
If anyone has a R230 / latest facelift parts car and would consider selling the rear left wheel wheel liner - please let me know.
Thanks,
/John.
I did contact a few people on Facebook, that claim to part out compatible SL550's. So far, only a scammer has responded!
Overall, I find it is quite a bit harder to find parts for an SL550, compared to my S550. I think about 4-5 times more S class cars were produced, compared with SL class. SLs may be more of collector cars, too.
Spammers: Please don't even think about contacting me via PM. If you don't have a post history on this site you will be ignored.
I've patched up some of the under-body panelling pretty successfully with tek screws, alu strip etc. You might need to source some similar hard plastic sheet. Sprayed matt black it will all blend in well.
I may be able to patch my liner up as I have plastic welding equipment. I did patch minor cracks on the under-floor panels. But, it would be nicer to get a clean used fender liner as it is more visible than an under-floor panel.
Thanks,
/John.
Thanks,
/John.
Why don't you buy this, it is perhaps US$60?
https://www.ebay.co.uk/itm/224131549...3ABFBMuKL454hl
Would need posted, obviously, worth a try?
I today tried to add to my eBay cart and check out but I got a message saying that the seller would not ship to the US.
So, the only way would be if someone in the UK or EU purchased this for me and shipped on to the US.
The fender liner material is quite rubbery and folds up nicely into a 25 inch long roll that is about 20 inches in diameter.
The weight is about 3.25 lbs.
So, doable with some assist
Annoying though that such an item seems unavailable in the US.
Thanks,
/John.
Edit: This made me do some research whether there are companies specializing in forwarding goods purchased in the UK to other countries.
It turns out that this is quite common: https://www.google.com/search?q=ebay...arding+company
I created an account for forward2me.com and got a quote for 25x20x20 inches weighing 3.5 lbs: 150 UK pounds, which is some $185 US.
Very pricey and total would be around $245 US. Given that, it would make more sense to patch up my old fender liner with my plastic repair tools.
So, it seems I'd better be patient and try to find one in the US.
$150 ...I'm not paying that ...I went ahead and researched and found you can get something online that may be able to be customized (simple cutting) to somewhat temporarily fix the need. My issue was that where I recently moved to (Idaho, from California in the USA) rain and snow in the winter will start to make some issues after time ...with no rear liner, moisture will DEFINITELY affect any systems in the trunk area....which we know...is not something you want to deal with ( electrical nitemares)...keep looking...eventually we will find what we are looking for my friend...good luck with your searching, PEACEOUT!!
I can donate my old L/R liner to you if you are interested (once I've received the new one - to make sure I don't end up with no liner at all).
It requires some plastic repair to be 100% okay but it does protect the rear valve unit and the inner side of the fender okay. See my original image for its condition.
I bought my SL550 from a used car dealer in Los Angeles a couple of months ago. He told me that some bolt was loose when he picked up the car from auction and that the rear wheel was rubbing towards the wheel liner.
I don't know how the rear damage by the muffler could have happened though.
Thanks,
/John.
Thanks,
/John.
The old one was donated to Specialized and will ship out tomorrow.
