SL/R231: Auto seat
Old Mar 29, 2013 | 08:56 PM
Tezer's Avatar
Mercedes SL 550
Auto seat
Is it possible to have the drivers seat roll back when the door s opened and forward as it closes? I hope.
Old Mar 30, 2013 | 12:18 PM
California John's Avatar
2022 AMG SL63
I don't believe so. The only controls are manual - on top of the seat at the outside.
Old Mar 30, 2013 | 12:42 PM
BigHat's Avatar
Veteran: Marine Corps
'24 CLE 53
I'm going to assume you aren't referring to access behind the seat and are looking for a more comfortable ingress/egress, but need to be up closer to the wheel and pedals to drive.
I don't know of anything automatic, but nothing to stop you from programming seat memory position one to move the seat aft and into the position you like to enter and exit the car and seat memory position two to where you like to be positioned to drive. Almost as easy as automatic.
Old Mar 30, 2013 | 07:52 PM
Tezer's Avatar
Mercedes SL 550
thanks,that's what I do now. I was driving a Jag S type "R" that offered that automatic feature.It was nice.
Old Mar 30, 2013 | 07:54 PM
Tezer's Avatar
Mercedes SL 550
thanks-my Jag, S type R had that feaure,it was nice
Old Mar 30, 2013 | 09:42 PM
Wolfman's Avatar
Super Moderator
That feature was available in the old SL. When opening the door, the seat would move and the steering wheel went up.
It could be set in the center cluster as off, steering wheel only or steering wheel & seat.
I had it set to the last setting but it never worked since I am 6'3" and my seat was too far back to activate the seat movement. Same for my wife.
So on the old one you had to shorter with the seat further forward to actually notice it.
On the new SL, only the steering wheel adjusts (easy entry/exit). They probably found out that it was working for most people due to the default seat position.
Old Jun 7, 2013 | 07:48 PM
impex4's Avatar
'22 S580 / '21 911 Turbo S / '20 Range Rover Autobiography
it is availablke on the new SL - it is a setting in the trip computer - called
"EasyEntry"
Old Jun 8, 2013 | 06:10 AM
Daytona-flyer's Avatar
AMG SLS & S coupe
The easy entry only raises the steering wheel. My Corvette's sest goes back when I open the door and goes forward when I put the key in the ignition..
What I did in my SL was to set the seat position to the rear. I raised and retract the steering wheel and saved it to memory.
You have to hold the button until the seat is in the desired position. A small pain in the butt.
Old Jun 9, 2013 | 08:59 AM
impex4's Avatar
Sorry, I stand corrected
Old Jun 9, 2013 | 04:17 PM
Tezer's Avatar
Mercedes SL 550
Red face
thanks for your help,guys.wonderful car!
Old Jun 10, 2013 | 05:16 PM
Gunther's Avatar
1988 560SL (sold); 2001 E430 (sold); 2004 SL500; 2009 CL550
They may have changed the system for less knowledgeable people - like a friend of mine who had a CLK with that function and kept turning the car in because the seat would stop partway....unless the Service Advisor asked him if he was starting the car and putting it in gear before the seat got to the driving position - causing it to stop so it wasn't in motion when the car was being driven.
Old Jun 10, 2013 | 07:40 PM
Tezer's Avatar
Mercedes SL 550
I think I'm convinced now to just use seat position 1 for my choice, and 3 for the seat to go all the way back as that"s the easiest for me to exit-thanks for your help!!
Old Jun 11, 2013 | 06:22 AM
AMG SLS & S coupe
I just noticed some minor wear on the drivers seat bolster. Put the seat back!
Old Jun 11, 2013 | 03:12 PM
Tezer's Avatar
Mercedes SL 550
I will cause I'm short
