SL/R231: I can't find the auxilary battery location on my 2015 SL 400
Old Jul 9, 2016 | 12:44 PM
Willi Seeger's Avatar
2015 SL 400, 2001 SL 500 1937 Chevy Panel Delivery hot rod 2004 Ford F-150
any idea where to look
Old Jul 11, 2016 | 08:01 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to R231 forum...
i believe there's only 1 battery in the trunk...
Old Jul 11, 2016 | 11:37 AM
can't find the auxilary battery on my SL-class (R231)
It was hit in the nose an set for a while
The main battery in the trunk was DEAD and I put a new one in
It runs and drives but the on dash display gives the following errors
EBD inoperative
Auxiliary Battery Malfunction
Parking brake -(see owners manual)
The parking break appears to be dragging or still on
the last 8 on the vin are FF034596
Also any suggestions on how I can reset the computer
Thanks for your help
Old Jul 12, 2016 | 04:48 PM
Talking can't find the auxilary battery on my SL-class (R231)
OK ... Finally I located the auxiliary battery on my 2015 SL
It is under the fuse box behind the passenger seat
NOW I can replace it and hopefully loose al those non functioning items
Old Jul 12, 2016 | 07:02 PM
Smile can't find the auxilary battery on my SL-class (R231)
Hi again and thanks for the location of the computer
I will have to check it out
Old Jan 3, 2017 | 12:42 PM
threeMBs's Avatar
Only MBs - the best or nothing
NA
Old Jan 24, 2018 | 10:24 PM
Pennetta's Avatar
19 E53 AMG Cab, 21 Land Rover Defender 110S, 20 LR Discovery HSE, 23 Ford Bronco 2dr 7spd Manual
Mine only has one battery
Old Jan 14, 2019 | 07:23 PM
Zogman's Avatar
2015 Mercedes Benz SL400
Is my auxiliary battery for my 2015 MB SL400 (276)?
My VIN is: XXXXFF034454
1. Is my auxiliary battery under the fuse box behind the passenger seat?
2. If I were to replace it do I lose some (a lot) of electronic settings?...
3. ...can I keep the leads hooked up to my battery tender so as to not lose the electronic settings while I replace it?
thanks
Old Jan 15, 2019 | 02:34 PM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
You are in for a big surprise in the future.....
Old Jan 16, 2019 | 01:34 PM
Zogman's Avatar
What does that mean - can you answer my questions?
Old Feb 2, 2019 | 09:59 PM
Dr. Manhattan's Avatar
'17 SL450, '25 Lyriq, '25 Sonata Hybrid, '96 Corvette GS coupe
I think he means that you do have an auxiliary battery...somewhere.
Old Feb 3, 2019 | 08:49 AM
Zogman's Avatar
I found the auxiliary battery behind the passenger seat!
I found the auxiliary battery behind the passenger seat. However, I still wonder if I lose all preprogrammed settings in my car if I detach either the main or auxiliary battery to get them replaced. Can anyone help me? Thanks!
Old Feb 3, 2019 | 10:26 AM
TennesseeZ4's Avatar
2019 E450 wagon: 2019 BMW 430i: 2013 Chevy Traverse: (departed)2013 SL550 & 2019 E450 cab
D49 posted a great battery reference link a bit ago: you might find what you are searching for on this page: https://mbworld.org/forums/sl-class-...ent-guide.html
Old Feb 5, 2019 | 05:27 PM
I know the aftermarket sells a cheap little cigarette lighter plug with a pigtail that accepts a 9-volt battery, just for maintaining enough system memory voltage to avoid such issues when temporarily disconnecting a vehicle's battery. It works, too...but I have no idea if, or how well, it would work on a car that has two batteries, with one of them disconnected.
Old Feb 6, 2019 | 02:56 AM
rorywquin's Avatar
Shanks’s Pony
CTEK chargers have a mode for "imitating" your battery while you remove the real thing to maintain all your settings!
