SL/R231: Last Visit Under Warranty/Issues?
Old Apr 2, 2022 | 11:37 AM
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
I'll be taking my SL to my dealer next month for its last visit under warranty. Making a list of possible issues.
So far I have the subframe corrosion issue, cam sensor leaks, timing cover leak. Both engine and transmission mounts have been replaced under warranty already.
Any other items I should mention? Thanks.
Old Apr 2, 2022 | 10:04 PM
JettaRed's Avatar
Veteran: Army
Engine and tranny mounts? How many miles are on your car?
Check for hydraulic fluid leaks in the trunk. Have you operated your top yet this year?
Old Apr 2, 2022 | 10:12 PM
rmorin49's Avatar
Veteran: Army
31k miles. Put the top down when I installed the new auxiliary battery.
Old Apr 2, 2022 | 10:53 PM
JettaRed's Avatar
Veteran: Army
Originally Posted by rmorin49
31k miles.
That seems like low mileage to replace the engine and transmission mounts. I had to replace the mounts on my 2004 SL500 last year, but it had over 100,000 miles and was 17 yers old. How did you determine the mounts were bad? Did the car just feel weird one day when you pull away from a traffic light?
Darn! Forgot to do that when I replaced mine. Woulda made it easier.
Old Apr 2, 2022 | 11:16 PM
rmorin49's Avatar
Veteran: Army
I had a vibration wen idling in Drive. First they replaced the transmission mount, I guess there is only one. Vibration was reduced but still there. Replaced the motor mounts, I guess there are two. Vibration gone.
Old Apr 3, 2022 | 12:35 AM
JettaRed's Avatar
Veteran: Army
That's correct. One tranny mount and two engine mounts. I'm just surprised they failed so early.
Old Apr 3, 2022 | 09:19 AM
chassis's Avatar
2017 GLE350 4MATIC
How about compression check and borescope looking for cylinder scoring? Assuming you have the M278 V8. Might need to pay a Dx charge but cheaper than a new engine.
Old Apr 3, 2022 | 11:59 AM
JettaRed's Avatar
Veteran: Army
Nope. He has an SL400 with the M276 V6. Unlikely the dealer will do that without charging a month's worth of labor.
Old Apr 3, 2022 | 12:39 PM
W205C43PFL's Avatar
Good thing OP has the M276, that is a proven reliable engine.
Old Apr 3, 2022 | 04:01 PM
chassis's Avatar
2017 GLE350 4MATIC
Thanks, the profile info with car model details is not visible in the mobile version of this site. Now I see it, yes the M276 is reliable.
Old Apr 3, 2022 | 07:45 PM
W205C43PFL's Avatar
Yup, just as reliable as yours
Old Apr 4, 2022 | 09:28 AM
steve sl550's Avatar
1986 560SL, 2017 E300, 2018 Sl550, 2020 E350
Hi Chassis,
Please advise where to find "profile info with car model details" per your post #10 above
Tx
