SL/R231: Multiple Batteries (R231)
Old May 18, 2022 | 03:14 PM
octony9717's Avatar
2020 E350L - 2018 SL450
Can anyone explain the multiple batteries operation and order of consumption (what does what)?
Old May 18, 2022 | 03:27 PM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
https://bestride.com/research/car-do...-two-batteries
Old May 18, 2022 | 03:58 PM
octony9717's Avatar
Thanks for the link UT. I was hoping for a bit more detail if possible. Are they wired in parallel or does each battery have a function.
The R231 has the main in the trunk and secondary behind the passenger seat correct?
I notice on the consumption panel there is a graphic for battery and it lights up in a pretty non-standard manor. Sometimes its most green under coasting and other times its under breaking like an MGU-K.
Is there a best way to charge them?
Just wondering.
Old May 18, 2022 | 05:57 PM
I believe the light is intended to show transmission function, at least it is that way on my R231. A green “D” means you are literally coasting, not accelerating or braking. I believe a bad or discharged battery light would be red in color.
If I keep a MB for over 5 years I have the batteries automatically changed out. The search function on this forum will show you hundreds of posts on the subject including getting the safety cage off the battery behind the passenger seat. Also Google “Why MB has two batteries” will give many web pages in the subject.
Old May 18, 2022 | 09:19 PM
JettaRed's Avatar
Veteran: Army
Just wondering.
Check your owner's manual. I believe it states to charge them using the terminals in the engine compartment. @rmorin49 had a thread going a short while ago because he found battery charger leads on the battery in his trunk that were added by the previous owner. If you are going to use a trickle charger, make sure you know what you are doing.
In my previous SL500 (R230) I added semi-permanent leads for the battery in the trunk since when that dies, all of your "electrical consumers" shut down.
Old May 19, 2022 | 04:43 AM
rorywquin's Avatar
Shanks’s Pony
There are a few long discussions about the batteries in this 231 thread - rather than repeating it all here, do a quick search. AFAIK no one had yet seen a wiring diagram and there is a lot of discussion on wiring, charging etc etc on the batteries.
The green bar that shows up is regenerative braking.
FWIW AGM does not like “trickle charging”. Better to charge and leave and then top up as needed.
MB recommend (in the owners manual) use of the jump start posts under the hood for charging. No need to muck about with connections in the trunk or on the Aux battery.
Old May 19, 2022 | 06:35 AM
JettaRed's Avatar
Veteran: Army
From what I can find on the subject, AGM batteries do need to be trickle charged, but you must use a charger designed for AGM batteries. Generally CTEK chargers are considered some of the best, if not the best, you can get. They are often relabeled and provided with certain high performance automobiles by the manufacturer.
Old May 19, 2022 | 07:18 AM
rorywquin's Avatar
Shanks’s Pony
Yes a charger that is AGM compatible must be used.
MB chargers are rebranded CTEK and CTEK are good. I’ve had one since about 2008 that has been used and abused and it just keeps going.
Old May 19, 2022 | 12:01 PM
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
Previous owner of my SL had installed a CTEK pigtail on the auxiliary battery but I put one on the main battery and have been using it. So far it seems to be maintaining both batteries.
Old May 19, 2022 | 11:24 PM
octony9717's Avatar
I wasn't aware this had an MGU-K circuit. This green light comes on when I get off the gas not when I brake.
Old May 19, 2022 | 11:43 PM
octony9717's Avatar
On my R231 the jumping terminals are in the engine compartment. I have yet been able to locate the main battery though. It must be buried. My owners manual doesn't mention the location at all.
Old May 20, 2022 | 02:17 PM
rorywquin's Avatar
Shanks’s Pony
If you go into the boot / trunk and keep removing liners, you will get to the cranking battery (2 layers and some polystyrene fillers).
Pigtails are a waste of time & a placebo effect. Use the jumper points as recommended by MB and you will be fine.
I’ve been keeping my batteries healthy from the jump start points for 5 years now (19,000 miles). I had the battery tested (because I’m getting "blind spot assist" & "lane keeping assist” warnings) at a Varta (MB OEM battery manufacturer) authorised tester yesterday and he says the batteries are perfect.
I’ve never had a problem with my batteries even, with the limited use my car gets.
Old May 20, 2022 | 02:26 PM
JettaRed's Avatar
Veteran: Army
I was getting the same error and replaced both batteries (got ‘em at FCP Euro) and the errors went away.
Old May 20, 2022 | 02:54 PM
rorywquin's Avatar
Shanks’s Pony
Oh thanks for that info. My car is in for service in 2 weeks & I’ll get them to check.
Old May 21, 2022 | 04:44 AM
chassis's Avatar
2017 GLE350 4MATIC
Rescue card shows batt locations
http://rk.mb-qr.com/en/231/
Old May 21, 2022 | 04:46 AM
rorywquin's Avatar
Shanks’s Pony
You can also scan the QR code inside the door.
Old May 21, 2022 | 06:40 AM
ThatsMyDawg's Avatar
SL 400
Yeah I just purchased the replacements for the two batteries yesterday from MB. I plan to install them Sunday, if it is not raining.
Old May 21, 2022 | 09:35 AM
JettaRed's Avatar
Veteran: Army
Interestingly, there was no indication otherwise that the batteries were (or battery was) borderline weak.
I know you're in the UK, but here are the batteries listed on FCP Euro's site.
https://www.fcpeuro.com/products/aut...odyssey-49-950
https://www.fcpeuro.com/products/mer...mer-0009829308
Certainly ain't cheap! But, then, what is?
Old May 21, 2022 | 09:39 AM
JettaRed's Avatar
Veteran: Army
The small battery is easier to access if you put the top down. That way you're not squeezing in the tiny space behind the passenger seat.
FWIW, I did not have a lot of difficulty removing the plastic cage on the aux battery. You just need to jiggle stuff around. I did find, however, that the aux battery I got had the terminals in a slightly different orientation and I could not get the protective plastic cage back on. So, I didn't.
Old May 21, 2022 | 09:45 AM
JettaRed's Avatar
Veteran: Army
BTW, I also changed the batteries one at a time and did not attached any code saver device to preserve settings. No harm done.
Old May 21, 2022 | 10:31 AM
rorywquin's Avatar
Shanks’s Pony
All good info thanks. I’m going to start with the AUX and see if that helps. As mentioned, I had a Varta (OEM in my car) agent test mine (cranking battery) and they said it is fine.
Old May 21, 2022 | 10:03 PM
rmorin49's Avatar
Veteran: Army
Buy the OEM battery if you want to ensure the terminals will be identical. Agree that it is much easier to install the AUX battery with the top down.
Old May 22, 2022 | 06:14 PM
SL 400
Thankfully I was able to replace both of my batteries this morning. So glad I did it first thing, because it’s storming like no other right now. Everything went smooth and easy and was finished both in 30 minutes total.
Old May 22, 2022 | 08:04 PM
JettaRed's Avatar
Veteran: Army
Does your car start?
Old May 22, 2022 | 08:12 PM
SL 400
Are you joking?
Yes. Soon as I was finished my wife and I took a drive out of town to have lunch with our daughter. A few hours later we returned. Later I went for a Walmart run and such. Now I am back home and all is well.
I even think my magic sky is quicker between transitions since the new batteries, but I can’t confirm that.
