SL/R231: what engine oil is best for tuned Sl550, 500 , 2013
Old Jun 24, 2022 | 10:31 AM
Tommyboy928's Avatar
89 SL500 Silver ,97 SL500 Carlsson 04 Mercedes SL55 AMG , 07 Mercedes SL55 AMG convertedBlack series
hi, guys , what oil is best for this 2013 model sl550 , 500 in Europe ? car is tuned ECU and is amazing fast.
Old Jun 24, 2022 | 04:18 PM
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
I believe MBUSA recommends Mobil 1 European Formula 0W40.
No clue about Europe LiquiMoly is good.
Old Jun 24, 2022 | 06:11 PM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
M278 specs Mercedes 229.5 rated oil. (See attached pdf)
factors when choosing viscosity should include, mileage and climate.
There’s a camp that believes newer thinner oils reduce cold start wear and tear on turbocharged engines. Newer Mercedes spec oils, such as the oil used in the M256, go as low as 20 weight. Also newer gen oils are supposed to burn cleaner reducing carbon on direct port injection motors. Mileage is also improved because of the thinner oil.
Here’s the Mercedes operating fluids website listing approved manufacturers and products.
https://operatingfluids.mercedes-benz.com
File Type: pdf
Old Jun 25, 2022 | 02:03 PM
Bitbytr's Avatar
'13 SL550 Mars Red, Designo White interior, B and O sound
I think also Mobil Super Synthetic Formula B 5W-40 ... According to the specs provided by 'crconsulting'.
Old Jun 27, 2022 | 11:24 AM
I have this oil sitting , probaly i can use that ? Motorolje MOTUL 8100 X-CESS 5W40 4L B41_104256
Old Jun 28, 2022 | 03:30 PM
Thats what I’m currently using. Good Stuff 👍
Old Jun 28, 2022 | 04:45 PM
yea, think its ok yes, we will teflon tret engine same time change oil with 1 liter QMI teflon engine treatment, internal friksjon will go down alot. Good for turbo lubrication also.
rmorin49's Avatar
Veteran: Army
I think the next Mobil1 rebate program starts on July 1. I buy 5 qt jugs at Walmart for around $25. After rebate it brings the price to around $4/qt.
Old Jun 28, 2022 | 06:33 PM
Dr. Manhattan's Avatar
'17 SL450, '25 Lyriq, '25 Sonata Hybrid, '96 Corvette GS coupe
Do they actually have the European Formula M1? That's cheap. I've been buying M-B's 5W/40 for the same price as most other correct oils that are available (just < $7/L). My impression is that M-B's oil is just repackaged M1 anyway...at least, here in the U.S.
Old Jun 28, 2022 | 06:55 PM
rmorin49's Avatar
Veteran: Army
Yes, they do it at least the ones in my area. European Formula 0W40.
Old Jun 29, 2022 | 04:05 AM
JettaRed's Avatar
Veteran: Army
I would NOT use any oil additive, especially Teflon additives! Years ago I had used Slick50 in a vehicle I had. After a couple thousand miles, I started getting a lot of noise at startup. Turned out to be clogged hydraulic lifters from the Teflon solidifying and flaking in the oil before it could be filtered, according to the mechanic that replaced all my lifters. There is a reason most new car warrantees warn against using oil additives.
