SL/R231: Exterior A-Pillar Trim
this may help
https://mbworld.org/forums/sl-class-...ml#post8328028
The plastic push in clip locations are circled in red, (clips are not present in pic) the rivet and torx head screw locations in green.
Good Luck
edit for clarification : doesn’t come with the 3 push in clips, rivet and bolts
Here's a link to the item I ordered. From the diagram and note, it looks like it comes with one or more clips and a molding plug (whatever that is). If I need a new rivet or clips, I'll try to get them locally. Thanks for all your help.
https://www.mbpartsource.com/oem-par...23169001879040
But, I also cannot hear what my wife says. I hear her making noise, but I don't understand what she says. Had my hearing checked and I am deaf at certain frequencies. That's my story and I'm sticking with it.
Up to post #5 it looks like exterior which is cheap and easy to replace
Starting with post #6 (Jettared) it looks like all of the part #’s and pics are for the *interior* trim which is more expensive and harder to replace.
Just want to make sure we are all talking about the same thing.. the thread title refers to the exterior trim only.
https://www.mbpartsource.com/v-2015-...r-trim-pillars
Selling one on eBay right now (pictured above)
Every one of them (so far) has come with clips #16 pre installed.
What they don’t come with is:
Part #19 (plastic rivet). Plastic rivet is the typical MB rivet where you remove the center pin to pull the rivet. Make sure your car has one but completely reusable
Torx head bolts #13 x2 (reusable)
And the push in clips #14 x3. You may be able to reuse yours but those are usually pretty brittle.
If in doubt, wait till the A pillar comes in unless you want to order extra parts just to be safe…
