SL/R231: DIY oil change with Mobil 1 oil filter
Old Aug 14, 2025 | 07:18 PM
Turbosnake's Avatar
2013 SL550
So I am getting conflicting information about what Mobil 1 filter to use on my 2013 SL550. The Mobil site says one number but every parts store I check says that isn't correct???
Just wondering for those of you that have done your own oil change with a Mobil 1 filter what is the correct part number?? Also where did you buy it at?
Thanks so much!!
Old Aug 14, 2025 | 07:43 PM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
Thanks so much!!
Welcome,
Congratulations, the SL is a great car.
Most folks use Mobil 1 oil but MANN and Hengst are considered OEM for filters.
See below, Factory filter, MANN and Hengst.
Also much easier to suck the oil out vs jacking up the car. But always nice idea to get under a new car.
Good Luck
Old Aug 14, 2025 | 07:46 PM
Turbosnake's Avatar
2013 SL550
Thanks so much for the help!!! So sucking it out is easier that putting it up on ramps??? I guess I am going to have to change my way of thinking with this thing... My first Merc
Old Aug 14, 2025 | 08:03 PM
I guess it depends on your ramp system, but using a MityVac is so quick, it’s hard to beat.
something like this, if you have a compressor.
Amazon Amazon
But as mentioned, always nice to get under new (to you) car….
Good Luck
Old Aug 14, 2025 | 09:59 PM
W205C43PFL's Avatar
^This
For M276 for example, WIS actually calls for top extraction for some models.
Old Aug 15, 2025 | 07:38 AM
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
I use a lift and drain it, old school. A thorough annual inspection of the undercarriage is a good thing.
Old Aug 15, 2025 | 08:58 PM
W205C43PFL's Avatar
Although I do that as well, as you said, to check for leaks if any but I do that every other change instead. So top then next time bottom.
Old Aug 16, 2025 | 08:18 AM
JettaRed's Avatar
Veteran: Army
With regard to filters, I only use Purflux, which is the OE for Mercedes filters.
Old Aug 16, 2025 | 08:49 AM
Welcome back…
Purflux is good too.
OP has 2013 M278, don’t believe that filter will fit
Old Aug 16, 2025 | 09:35 AM
RA1126's Avatar
I buy everything at the Mercedes-Benz dealership. This includes any available parts, batteries, oil(s) and filters. If it's in a Mercedes-Benz package, I want it. But that's just me.
Old Aug 16, 2025 | 09:43 AM
Sathinas's Avatar
S65
Don't forget to also get the Mercedes branded windshield wash fluid and tire air.
Old Aug 16, 2025 | 09:45 AM
Never a bad idea in today’s “knockoff” world. Incredibly, fake parts are an issue….
Old Aug 16, 2025 | 09:55 AM
W205C43PFL's Avatar
Just buy directly from mbparts.mbusa.com might be cheaper too.
