SL/R231: Oil Pressure Solenoid
https://mbworld.org/forums/e-class-w...et-nozzle.html
Crconsulting sums it up pretty well in post #18 of the thread.
You will hear or read both sides of the story, but should ask what makes sense to you. All the claims about premature wear of chain guides seem ridiculous. For years, Mercedes instructed its dealerships to ignore the DTC P06DA00. And there are other manufacturers of two-stage oil pumps that confirm the PRIMARY purpose of the two-stage pump is to improve fleet gas mileage and maybe negligible emissions improvements. What makes no sense is to think that operating the oil pump normally and linearly somehow harms the engine, or that critical components would be intentionally built to fail under normal oil pressure (35-60 psi). With the solenoid enabled, there is a sudden shock to those components at 3500 rpm when the oil pressure doubles. That seems more destructive than a gradual pressure increase based on engine rpm.
It’s been shown that the Start/Stop feature of virtually all modern cars, again in order to improve gas consumption, is damaging and life-shortening to the engine. Just because Start/Stop was “engineered” for your engine, does disabling it harm the engine? No, it actually improves the survival of engines over many, many miles.
It is totally up to you what you do to your car, but do your research and decide for yourself. For me, I really like knowing that I have the best lubrication possible when I start and run my engine.
$55 on RockAuto (plus shipping) and about half that on AliExpress. (I would never try to save a couple of dollars on parts if I was really going to install this on the oil pump. The labor costs are too high to not use Genuine or OE parts.). Even Amazon has them for about $32. Again, these aftermarket solenoids are only to provide the impedance to keep the DTC from triggering.
