SL55/63/65/R230 AMG: remote key stopped working
Old Jan 22, 2007 | 03:23 PM
mark anderson's Avatar
2019 S63,2015 SL63, 2007 SL55, 2006 SL55, 2003 SL55
Over the weekend I stopped to get a bagel and when I came out 5 minutes later my remote would not open the door. I tried several times but no luck. I used the key to open the door and the alarm went off. Tried the key fob severl more times but no luck. Had my wife pick me up and take me to work where I had a spare key and when I returned they both worked. This is the second time in 6 months I've had the problem. Anyone else had the same or know what it might be?
Old Jan 22, 2007 | 03:42 PM
bltserv's Avatar
2005 SL55, 2000 CL500
Key Battery
Sounds like time for a new battery in your Key.
Have it done at the Dealer $ 25.00 a key or more.
Look in your Owners Guide and go to Save-On $ 3.00 a key.
The trick is to open the key without damage.
You need to replace the Battery in the key about once a year.
Old Jan 22, 2007 | 03:46 PM
JohnCL's Avatar
'01 C320 || '14 Honda Pilot EX-L
You don't need good batteries to make the key work in the ignition. Once you open the door with the steel key and put the smartkey in the ignition the alarm will stop and you can start the car. The batteries are for locking and unlocking only.
Old Jan 22, 2007 | 04:20 PM
Thanks but they key is only about 1 year old and the red light does still come on. I guess it could still be bad so maybe I will replace the battery anyway.
Old Jan 22, 2007 | 04:21 PM
After opening the door with the steel key I did try the key in the ignition but it would not turn.
Old Jan 22, 2007 | 04:33 PM
JohnCL's Avatar
Ah, I see. A friend of mine had hers fail and they replaced her keys and ignition module. Good luck.
Old Jan 23, 2007 | 11:36 AM
Back to the dealer tomorrow. I will post the problem if they can find one. My warranty is up in a few months and I think I will look for an extended one.
Old Jan 23, 2007 | 01:05 PM
sprins's Avatar
G55, SLS, smart eq
An extended warranty might be the best money you ever spent with these cars. You can be lucky, but you can also be in misery.
On topic. My S55 exhibited similar behaviour (plus random battery drain) as your SL55 and eventually they replaced the ignition module that went bust.
Old Jan 23, 2007 | 05:10 PM
Both of my batteries have been replaced under warranty in the past 6 months so maybe it is the same problem.
