SL55/63/65/R230 AMG: upgraded ic pump
Old Aug 6, 2007 | 12:11 PM
BiTurboAmg's Avatar
SL65 AMG
upgraded ic pump
Can any one with a 600 or 65 tell me what pump you used and why? Does any one that has done this have any data to show the before and after iats. I know the 55 cars use the big cm90 but I want to know what the v12tt guys are running. Also has any done the therma stat upgrade or know if it can be done on the v12tt's?
Old Aug 6, 2007 | 03:34 PM
Vadim @ FD's Avatar
S600TT, R350
I am not aware of anyone on 65s with CM90. You can use CM30 with similar results.
Old Aug 6, 2007 | 04:19 PM
JAYCL600's Avatar
new balance
Not that many people datalog, and even fewer biturbo owners go that far, I have shared my data with you which was compared to the data that I was told was from NSM's car after the "intercooler" upgrade and they were identical, my figures also seem to be inline with what you datalogged recently, correct me if im wrong. Its a killer 94 degrees Fahrenheit right now, ill go make repeated runs and tell u the outcome.
Old Aug 6, 2007 | 06:21 PM
BiTurboAmg's Avatar
SL65 AMG
It just seems that the 55's run much cooler iat temps and coolant temps and I dont know why. I would think with the air/water intercoolers on the v12tt's they would be the same.
Old Aug 6, 2007 | 06:28 PM
JAYCL600's Avatar
new balance
yes the 55's do run much cooler when the ic upgraded
Old Aug 7, 2007 | 04:15 PM
Vadim @ FD's Avatar
S600TT, R350
65 and 55 run about the same in terms of IATs.
Old Aug 13, 2007 | 11:55 AM
SLcharger's Avatar
SL55AMG, ML420CDI, E320TCDI
From own experience, i know that the stock intercooler and pump on a 55 is just up to it, on the stock car, but only just. 55 drivers do from time to time experience the problem of low power, especially when they accellerate fast in between to trafic lights. The airflow thru the cooler is not big enough to keep IAT down, and there is no reserve in the system, the engine computer is disconnecting the kompressor.
I took the consequence and installed a bigger cooler and a bigger IC pump. Since then i have had no problems with IAT what so ever.
I dont know enough about the 600 to advise you, but a bigger IC pump would proberbly help keep the IAT down.
Old Aug 14, 2007 | 07:14 AM
theboogers's Avatar
2020 S560,14 ml350, 03 sl55, silver, pano, slr cams, evo headers, lsd, 2019 s63 cab.
slcharger- which pump and ic upgrade did you use? and pictures? thanks
Old Aug 15, 2007 | 09:23 AM
SLcharger's Avatar
[quote=theboogers;2367284]slcharger- which pump and ic upgrade did you use? and pictures? thanks[/quote]
Kleemann did it together with the tuning, and the I/C is their own product, but i am pretty shure that the pump is an electric one from Johnson Industries. Photoes wont show anything, everything is covered. Sorry.
Old Aug 15, 2007 | 03:06 PM
Vadim @ FD's Avatar
S600TT, R350
Kleemann uses Johnson CM90 pump.
Old Jan 10, 2008 | 08:52 PM
Chris-W's Avatar
sl55 AMG
can I just swap out my stock sl 55 AMG intercooler pump for a Johnson CM90 pump ?
If so can I get direct from Johnso and what flow rate increase can i expect?
Old Jan 11, 2008 | 04:03 PM
SLcharger's Avatar
[quote=Chris-W;2591955]can I just swap out my stock sl 55 AMG intercooler pump for a Johnson CM90 pump ?
Yes you can.
If so can I get direct from Johnso and what flow rate increase can i expect?[/quote]
I have no numbers, but it will help. The best thing to do would be to replace the coller as well.
Old Jan 11, 2008 | 05:32 PM
PTE's Avatar
PTE
05 ML-500 , 03 CLK5.5 AMG has left the Garage
Johnson Pump
Here is 1 that was posted in the Classifies https://mbworld.org/forums/showthrea...t=Johnson+pump Cheers ___PTE___
Old Jul 14, 2008 | 08:21 PM
Chris-W's Avatar
sl55 AMG
whats the difference between the Johnson CM90 pump and the Johnson CM30 pump ?
Which would better suit an sl55 amg ? and for what reasons?
Old Jul 14, 2008 | 11:07 PM
Murtaza's Avatar
C63S coupe, X5M
The CM90 flows 3x as much as the CM30 but requires significantly more work to install (larger tubing otherwise the tubing becomes the bottleneck), got this info from Vadim
Old Jul 15, 2008 | 07:18 AM
Chris-W's Avatar
sl55 AMG
So I'm stuck with the CM30 unless I want to start upgrading pipes as well but the CM30 is much better than the stock unit?
Old Jul 15, 2008 | 12:12 PM
Vadim @ FD's Avatar
S600TT, R350
Unless lines are upgraded CM90 and CM30 will end up pushing very similar volume of water through the system.
Old Jul 15, 2008 | 12:29 PM
Chris-W's Avatar
sl55 AMG
Can you supply the upgraded lines and if so how much would you want for them ?
Old Dec 22, 2008 | 07:37 PM
Rick SL55's Avatar
2005 SL55 AMG, 1986 Porsche 930S, 1996 Porsche 993tt
NEED HeLP!!!, I will install tomorrow the Johnson pump-Intercooler pump on my 2005 SL55 AMG.
Went to epc and is freezing on my computer and unable to get the info.
There's 2 electric pumps in the right side(passenger) of the radiator, one is smaller(lower pump) and the other on top is bigger.
Which one of the pumps will be replaced by the Jonhson pump, the bigger (top) or the smaller(bottom).
Also the stock pump has 3 hoses and the Jonhson pump has 2 conector for 2 hoses, the remaing hose should be clamped or what?
Big pump on the left and smaller pump on the right.
Jonhson Pump
thanks,
Ricardo
Old Dec 23, 2008 | 09:05 PM
Rick SL55's Avatar
IC pump is the big one(left on the pictures), the smaller one is the heater pump.
