SL55/63/65/R230 AMG: KLEEMANN Bi-Turbo ECU SPECIAL!
No, not particularly. I've never experienced any significant difference. We can remove load limitations, and get the car to hold a gear longer at neutral throttle inputs which is handy for road-course driving, but there's really no benefit on the 65 in terms of 1/4 times, or HP/TQ output. The AMG Speeshift program is quite nice, and there's not too much room for improvement there. It will benefit the 600 cars much more than the 65 AMG's.
There is no mention of SL55 only, so I assume the SL65 applies as well.
I attached the page for the R230 for your viewing pleasure (click to enlarge).
1 member here w/SL600 recently got the Kleemann ECU/TCU put down 500+ rwhp 680+ rwto I believe it was on a Dynodynamics which usually read lower than the most widely used Dynojet you'd easily see 520+ rwhp 700+rwto on Dynojet
These #'s equate to 634 Crank HP & 853 Crank Torque using 18% driveline loss
It will be FASTER than a STOCK SL65 AMG easily..
In my experience, 91 octane maps net real-world gains of 40-50 peak HP, but closer to a 100 HP gain in the low and mid RPM range. MB limits the amount of boost pressure in the low and mid RPM range, and our programmers are simply making more boost available earlier in the RPM range. Peak torque is limited to around 830 lb/ft., which is just under what that transmission is load rated for from MB. 100 octane maps will provide gains of 100 HP- right around 700. Peak torque remains limited to 830 lb/ft. We also do the usual things like remove the speed limiter, program for better throttle response, etc.
a friend of mine who owns a BMW dealer says he sees MB's come in with check engine lights all the time. He always tries to sell them BMW's....
So is it still good for $2500 ECU $500 TCUThank you!
We've had such a good "response" about the sale, we've decided to extend this bi-turbo offer until Feb. 1st. $2500.00 for ECU, $500 for TCU.
How does this work with you in another State if I want to have you do the program on my car?
Also do you have some sort of a senior discount for me having to put up with them on the roads all day? LOL! J/K
If you would like Kleemann tuning, you would need to remove and ship your ECU to Kleemann. They will flash it and send it back to you.
We are Kleemann dealer located in Charlotte, NC if anyone in the area is interested in this flash. I can also take orders from those who are not local to us if you like. Just pm, email or call
888 488 2028 EXT 257 or 704 525 0941 EXT 257
mkrisel@gmpperformance.com
I know you meant KleemannBTW make sure this vendor gives you this special pricing ie $2500 ECU $500 TCU as far as I know you can ONLY get this special pricing thru Kleemann directly "Special for MBworld members"
Wow thats cheap. If I had a V12TT I would jump on this offer!
