SL55/63/65/R230 AMG: Wheel fitment question (offset)? And another question -- how is driving with 19s?
Old Mar 10, 2009 | 11:00 PM
InTheBenz0's Avatar
GLC 63 S AMG / Corvette C8 / Jaguar SVR
On an SL55 or sl600
Size: Staggered 18x8.5 front
18x9.5 rear
What offset would I want in the front and what would I want in the rear?
On another note: how is driving with 19s all around on an SL?
I am torn whether to use 18s or 19s?
This car will be a daily driver in NJ seeing 11k miles a year give or take (north NJ)
Old Mar 11, 2009 | 12:28 AM
damian155's Avatar
SL55
i live north jersey also. I have Vellano VSH 20's on my sl55 but not a daily car that's what the Honda accord is for lol I hit a few minor potholes but my rims took it really well. I'm sure with 19's you'll be fine.
Old Mar 11, 2009 | 12:34 AM
InTheBenz0's Avatar
I had 19s on my 05 e500 and it gave it a bit harder ride, but was ok.
I don't know how the SL would handle it though, considering it is lower to the ground and what not.
I guess others with exp would be able to help me dictate the route I wanna go. Thanks for posting.
Old Mar 11, 2009 | 12:12 PM
lkirchner's Avatar
Several MB's Superperformance MK III Cobra
Originally Posted by InTheBenz0
On an SL55 or sl600
18x9.5 rear
I have 19x8.5 front and 19x9.5's (AMG 2 piece wheels) on my SL55 and the ride is good. I have not encountered any problems with wheel damage but I have had sidewall damage on the fronts.
Old Mar 11, 2009 | 02:37 PM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
I have 20X9 f and 20X10.5 r . -they are both 23 offset
Lowered car, no problems.
The ride has nothing to do with the rim size. Its because the larger the rim dia. ,the lower profile they make in tires sizes.
If you have 18s you probibly have 35/40/45 tires, if you have 19, 20s, you probibly go to 25 / 30 max tires.
You get down to about 1 1/2 inch tire sidewall. No bounce or cushion at all.
So choose a high profile tire and decide what diameter wheels you really want.
Old Mar 11, 2009 | 09:20 PM
carcommander's Avatar
2014 SL550
19" will make the car ride rougher, 20's will make it ride stiffer still. Not objectionaly but rougher. I have or have had both on an SL. 19's are damaged more easily than 18's, 20's are worse. For a daily driver I would stay with the 18's.
The 20's ruined a date for me in Atlanta.
Old Mar 11, 2009 | 09:27 PM
damian155's Avatar
SL55
thats just why i carry the spare.
Old Mar 12, 2009 | 09:17 AM
aza12345's Avatar
2005 SL55, 2007 Acura MDX, 2008 Acura RL
I know I will probaby be the minority on the site, but I think 19s look better than 20s and nicer than 18s.
Old Mar 12, 2009 | 12:47 PM
InTheBenz0's Avatar
Anyone able to help with what offsets I would want in the 18s (18x8.5 fr / 18x9.5 rear)
Old Mar 12, 2009 | 05:07 PM
2014 SL550
It in the manual. It varies alot. Around 30mm front and 35mm rear. I think the SL65 is 30mm front and rear.
Old Mar 14, 2009 | 03:47 AM
Thericker's Avatar
V12-Biturbo
On an SL55 or sl600
18x9.5 rear
Go w/19" whls the best compromise excluding 20"s altogether due to crummy ride, wheel damage, & slower excelleration, you retard the final gear ratio the larger you go in wheel diameter.
Also you can still run a healthy aspect ratio IE side wall thickness easily 35 all round. I'm running 19x8.5 frnt on 265/35/19 19x10.5 rear 295/30/19 would've gone 295/35/19 but they were not in stock whn I ordered.
You want the most possible side-wall in the frnt where MOST of your weight is to retain comfortable ride, IE 35 aspect ratio 19" or 40 on 18" wheel, the same thicker side-wall will be extremely important in the rear but more so for any traction on moderate-hard launches from dig.
I Laugh my **** off when I see these cars IE 55/63/600/65 w/20" wheels and 20/25 aspect ratio they're like skateboard wheels providing zero traction w/these high powered rides..
Old Mar 14, 2009 | 09:07 AM
okbarnett's Avatar
You misspelled ****, its ***
