SL55/63/65/R230 AMG: Anyone having this issue?
Old Feb 13, 2011 | 10:58 PM
MBH motorsports's Avatar
Former Vendor of MBWorld
C63, SL55, E55, CLS55, ML63, C55
The black glass on the sides of the rear window seems to be having its clear coat coming off. Has anyone else had that? Do you think its covered under warranty?
Old Feb 13, 2011 | 11:19 PM
cdsjklee's Avatar
2004 SL55 AMG EUROCHARGED. 2002 X5. 1999 SUBURBAN WHIPPLE SUPERCHARGER+MODs,04 M3 EUROCHARED
I have same problem, I think it is very common pboblem,
I did not try to fix it under waranty but it does not hurt to try.
Old Feb 14, 2011 | 01:02 AM
NikleinR6's Avatar
08 ML350, 2011 E550 Cab
Very common problem.. Replacement panels are like 50.00 each and take 2 secs to swap.. Search and you can find a lot of info and part numbers..
Old Feb 14, 2011 | 01:09 AM
NikleinR6's Avatar
Just to be helpful, Go here... https://mbworld.org/forums/sl55-amg-...ear-glass.html
Old Feb 14, 2011 | 01:12 AM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
I have...
had them replaced under warranty and had them denied under warranty. Depends on your dealer's attitude. Known issue.
Old Feb 14, 2011 | 08:36 AM
alx's Avatar
alx
yes. my 06 sl65 had the same thing + some rust on the metal brackets.
dealer replaced it under warranty without any issues.
Old Feb 15, 2011 | 09:28 AM
SL55K's Avatar
AMG
Yup i have the same problem
Old Jun 11, 2012 | 04:12 PM
LVDSB's Avatar
"2003" SL500 and E-320
Yes, I had the same problem on my 03 Sl500. The dealer wanted $500.00 to replace and install. I got some black gloss vynal strips and put them over the existing after sanding them smooth and it looks great. Whole project cost me about $10.00 and looks better then new.
Old Jun 11, 2012 | 04:15 PM
LVDSB's Avatar
Yes, I had the same problem on my 03 Sl500 and I got high gloss vynal and put it over the pillars. They came out better then new and the whole project cost about $10.00. Dealer wanted $500.00 to replace and install. Just heat it with a hairdryer for a perfectly smooth finish. Been over a year now and still looks brand new.
Old Jun 13, 2012 | 11:58 AM
cal1's Avatar
SL55, ML500 & Acura TL
Is this the little beast you are talking about?
If so, here is a DIY for you. https://mbworld.org/forums/sl55-amg-...ement-diy.html
The trim is just plastic.
Old Jun 13, 2012 | 12:08 PM
That was my issue. Strangely enough I put my top down this past weekend and snapped one of them in half. I've had the new ones on for a while and the top down many of times. I have no idea how putting the roof down caused the trim to snap, but it did. Big pop sound when it happened. Might have come a bit loose over time from the insane vibration from my cutouts. No now I'm in the market for new ones yet again.
Between that cranking off and a tire shop destroying one of my HRE center caps my car is slowly looking like a hunk of crap.
