SL55/63/65/R230 AMG: Installed Intercooler Pump....
Rating: Thread Rating: 2 votes, 5.00 average.
Old 04-18-2011, 12:17 PM
ForceFedSL's Avatar
SL55 AMG
I just wanted to share this information with fellow members. My 2006 R230 with 27,000 miles had the "case" of heat soak syndrome. I did a little research and decided to go with the latest generation Mercedes pump. The installation was very simple and took me roughly one hour. If anyone has any questions please feel free to ask away. Finally I decided to take apart my used pump to find out what the problem was, what I found was quite disturbing and you can check the pictures to see what I mean.
thank you
Attached Thumbnails Installed Intercooler Pump....-img00220-20110417-2022.jpg   Installed Intercooler Pump....-img00221-20110417-2023.jpg
Old 04-18-2011, 07:05 PM
cal1's Avatar
SL55, ML500 & Acura TL
Is that thing cracked in three pieces the impeller?
Old 04-19-2011, 12:02 AM
ForceFedSL's Avatar
SL55 AMG
What you see in the pictures, would be on the dry or "electrical" side of the pump, and yes its cracked in three places. You can feel the magnetic resistance but you can also see the dust from constant grinding of the teeth. Bad design? Or was it my pump alone that failed like that? Has anybody else taken apart their pumps?
Old 04-19-2011, 12:05 AM
M3nv's Avatar
Where exactly is the pump located? Is it easy to access? I was thinking about going with the Johnson pump
Old 04-19-2011, 12:18 AM
ForceFedSL's Avatar
SL55 AMG
I removed the passenger wheel, the wheel well lining and the under tray. VERY EASY and this makes the pump swap even easier. I chose the MB pump for ease of installation and peace of mind in case I have to take the car in to the stealership and I know they would frown upon a non MB product.
Old 04-19-2011, 04:45 PM
cal1's Avatar
I have not taken apart my pump. i had it replaced as part of a cooling and power mod through RT. My MB SA says the pumps generally do not fail completely just produce significantly lower flow rates.
Old 04-19-2011, 08:47 PM
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
Good to see a better pump coming from MB and that you did the job yourself.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old 04-21-2011, 12:39 AM
grmnpwrd's Avatar
CLK 500
thanks to me for that pump lol
Old 04-21-2011, 12:41 AM
ForceFedSL's Avatar
SL55 AMG
yes of course...and thanks to me for that install....
Old 04-23-2011, 02:48 AM
maxabo's Avatar
2007 Väth SL65 AMG. 2007 BMW Alpina B5s. 2007 BMW M6.
thank you
Could you please give me the product number..?
Hopefully the numbers are the same here in europe.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: SL55/63/65/R230 AMG: Installed Intercooler Pump....
