SL55/63/65/R230 AMG: Is LSD shudder normal?
Old Feb 6, 2012 | 03:40 PM
mark anderson's Avatar
2019 S63,2015 SL63, 2007 SL55, 2006 SL55, 2003 SL55
I've had 3 SL55's. 2 with LSD and one without and both cars with had the same issue.
At slow speed and under acceleration the rear end shudders to the point that passengers will notice. Does everyone with LSD experience this?
Old Feb 6, 2012 | 05:23 PM
EXECMALIBU's Avatar
SL65, 427 COBRA (CSX-3127)73 911S, 246GTS (DINO SPYDER), CORNICHE,1962 PORSCHE TWIN GRILLE ROADSTER+
Sl65 Shudder... I have definitely noticed it!
My SL65 has the factory LSD. Yes I have noticed a shudder and mentioned it repeatedly to the MB dealer... They tried to fix the problem and installed new Motor and trans mounts but the shudder is still there...
Old Feb 6, 2012 | 10:30 PM
alx's Avatar
alx
Shudder is mounts... Usually.
Old Feb 7, 2012 | 03:13 PM
Well my first SL had 3k miles on it and my second had 7k so I'd like to think they were still good.
Old Feb 7, 2012 | 05:48 PM
EXECMALIBU's Avatar
ALL my mounts have been replaced and there still is a shudder...
Everything was replaced and there is still a shudder...
Old Feb 7, 2012 | 08:29 PM
NCE500's Avatar
2007 E63, 2006 C55
Shudder
I think what you are experiencing wheel hop. Due to the torque/power, the rear wheels fight for traction and repeatedly engage/disengage traction in the process. Feels like a shudder.
My 600 has a touch of it in cold temps since adding a Quaife, much less wheel hop on warm days though.
Old Feb 13, 2012 | 07:48 PM
I don't think that's the case in mine as it's most notable at speeds under 10mph
Old Feb 19, 2012 | 10:08 PM
skratch77's Avatar
2005 E55
does it do it when you are turning? It sounds like you have a posi rear end and both tires are trying to turn at the same time all the time.
Check the air pressure and if it still does it I would guess thats just the way MBs lsds work.
You can try throwing a quiafe unit in there to see if its better
Old Feb 21, 2012 | 07:55 PM
Yes it only does this while turning and I agree that it's being caused by both wheels trying to turn at the same rate. I'm just surprised it is so noticable for a refined car. I'd expect this is some hard core sports cars.
Old Feb 22, 2012 | 10:11 AM
seattlekleeman's Avatar
Birel Shifter,2003 Ferrari ,1992 Mercedes 500E,Superformance Cobra,2005 SL55, 2004 996tt X50 PCCB
Shudder
Rear Toe Links dramatically benifit these cars.
Old Feb 23, 2012 | 08:06 AM
Stevant's Avatar
2005 SL55 AMG
I had the same problem after adding all the hp to the car. When I accelerated the rear would shudder. The torque would throw each wheel out causing them to fight eachother. There was really no good adjustment to correct the toe out under heavy acceleration. I purchased the Evosport toe links for my car and installed them. They replace the rear lower control arm yet are fully adjustable. Brought the car to MB, they did an alignment and the shudder is gone. They were able to bring the toe in on both wheels, they are a ball and socket design, not rubber mounts. The ride is not compromised in any way. Worth every penny, as you will see they are a little pricey but they are built well, and a fix I really needed. I did not enjoy my car without them.
That's my story, hope you have the same experience!!! Good Luck!!
Old Feb 25, 2012 | 07:56 PM
skratch77's Avatar
2005 E55
What you fixed is not what the op is having issues with.They are feeling like one wheel hops on the pavement going around turns becasue its turning the same speed as the other.In an open diff setup you wont feel anything ane they are talking about speeds at less than 10mph and not even giving the car any throttle.
what you have is the car trying to put the power down with all the extra torque it has and its moving the power from one wheel to the other as the diff is trying to put the power down to the wheel with less force.
Old Feb 25, 2012 | 09:40 PM
Stevant's Avatar
2005 SL55 AMG
All I can tell you is that after my Quaife went in I was having the same shudder issue. I completed all my mods at one time and it was explained to me it was a combination of the extra HP and the LSD. I think you agree that they are not the best car to put the power to the ground. I installed the toe-links and the shudder is gone. Maybe I'm off point with my experience but they did remove the shudder. I see they are referring to slower speeds so looks like it may be a different issue. I see what your saying about moving the power from one wheel to the other.
Just sharing my experience................
Old Apr 23, 2012 | 12:45 PM
jbaker1121's Avatar
MB: E55 AMG, CL550, E3004M Cab + other makes :)
That's what LSDs do...
