SL55/63/65/R230 AMG: More ABC questions
Interestingly, the warnings stopped showing up. Drove it 2 - 3 times a week for a year and a half, no warnings. Now warnings have returned, 'visit workshop' followed quickly by 'drive carefully' in RED and the ABC seems to shut off completely, car goes to highest setting, and is noticably bouncier.
I get one trip of 30 minutes os less after sitting off overnight, then RED on every start up.
No noise or leakage symptoms.
Any thoughts?
Rich R
The car needs to be read. It could be one of many things that can go wrong with abc. It could be a dirty fluid that requires a filtering and new filter. I have never seen this fix anything btw. It could be a valve body. It could be an abc pump or a shock. It could be one of the many sensors. Reading the car will point in the right direction.
IT is most likely the shock. Have it read and diagnosed first and then raise the car to see if there are any leaks. IF you need a new shock, I could give you a tip on where to get some for a good price :-)
BTW, who was that thief who asked for 3K?
The dealer price of the shock for the SL55 is 1800. Why is this guy charging $3000. what a thief
Good luck bro
Good luck bro
A dying abc pump is also audiably chatty when cold.
