SL55/63/65/R230 AMG: overZealous1's build thread
Rating: Thread Rating: 22 votes, 5.00 average.
Old Dec 9, 2012 | 10:51 PM
  #126
overZealous1's Avatar
sl55 amg
that it is!
Old Dec 14, 2012 | 02:04 AM
  #127
amok55amg's Avatar
SL55AMG + SL600 + E320 + A180
Originally Posted by overZealous1
luckily not all of oregon is required to do inspections or deq. luckily the border for no deq is only 5 miles from me. luckily, i have friends that live in that county that let me register my cars to their address. havn't deq-ed in over 15 years. lol. if not, hardly anything i have built would pass, haha.
I have to go every year so no-way off getting around cats - will have sports cats ..... but I do a little trick before going for the check up just a few 100 meters from the inspection site
Thanks for the link to cats kustom2k1
came up with a great design. instead of 2 3" pipes running length of car, i can merge pipes at front (the front of the x-pipe is all that matters anyways) then run into a single 4.5" pipe through center (will save weight and have more volume than 2-3" pipes) and then split off again for the rear. should make install a snap at just 5 separate sections. lowers cost also. if all goes good, it would be simple to reproduce for others. could even have center section put in press and make it oval.
3" pipe volume per foot= 84.72cu inx2= 169.44cu in
4.5" volume per foot= 190.68cu in
What kind of material are you using? Seen some make the flange in steel 321 .... which should be better to stand the heat. http://www.metalshims.com/t-321-Stai...ata-sheet.aspx
Also; some report problems with tears just beside or/and in the welding ..... some of it could be explained by them of not having followed a correct procedure for the welding .... I have seen some headers which has been welded inside (pipe to flange) as a socket weld ... and if your not careful - if you put the pipe all the way down to the bottom of the socket; then you're weld seam well most probably fail due the consisting warming and cooling of the steel since it has nowhere to go.
By the way overZealous1; did you not put up some info on heat exchanger? I have friend who sells radiator, Ac etc. - what size should I be looking for?
Old Dec 14, 2012 | 11:49 PM
  #128
sl55 amg
the one i found on ebay is going to be about as cheap as you can get. i posted a link earlier in the thread i think.
Old Dec 14, 2012 | 11:51 PM
  #129
kustom2k1's Avatar
03SL55
OZ, where you been, hows the car running?
Old Dec 14, 2012 | 11:56 PM
  #130
sl55 amg
a few more things i'm adding now.
doing dual aem widebands, and one of them reads boost too. you can datalog all of them too. the wb and boost combo gauge has a failsafe you can program into it also. if the a/f gets to lean (user programmable based on boost) then it will ground the failsafe wire. i am going to hook it up to a relay and interrupt the electro magnet wires to the supercharger. if a/f goes lean, it should kick the blower off. i got the gauge for $288 from an ebay seller. hell of a deal for it's capabilities and the failsafe.
decided to do the rear toe links. but, instead of paying the incredibly inflated prices that are out there, i am building them. $90 in materials. about crapped when i saw $1200 for them!! no shame! will be building them next week.
the deal misha has going on right now may be too hard to pass up. car has a couple little scratches, so, getting there widebody will give me a great excuse for a repaint!! going to sleep on it, but right now the answer is.............................
Old Dec 15, 2012 | 12:06 AM
  #131
sl55 amg
i been here, been spending alot more time over in the e55 section gaining info. alot more there! lol
car still has a little stumble, other than that great. great news on my search for competent tuners. i got a hold of john reed. john is local to me and known him for almost 10 years now. he is one of the best tuners in the world and is the guy behind all of the underground cars. luckily he knows jerry at eurocharged, so, i can have jerry doing the actual map manipulations remote and john expalining what the car is doing and giving insight over the phone while he is running dyno. i could not be more lucky than to have one of the best mercedes tuners working with one of the best tuners out there, both working together for the tune.
along with the stuff in my post above, i am just waiting to hear back on combo price on lsd and 3.23 gears. if i do the misha wb kit, i may hold off though since car will be down for awhile doing the kit.
i do bodywork and have painted many show winning paint jobs, so really looking forward to doing that. i have done some crazy paint jobs!! the sl will not lack in flash. haha
Old Dec 15, 2012 | 12:10 AM
  #132
kustom2k1's Avatar
03SL55
AEM DWB, pricey, but a great addition. Love the idea of having a fail safe. I got to see this. Rear toe link rape. The prices are nuts and if it works I'd buy a set.
I like the Misha kit myself. I've been in contact with a guy that sells a kit from Germany that isnt as drastic of a change. I found one headlight for the upgrade on ebay for a great price if your interested. I'll PM the link.
Old Dec 15, 2012 | 12:16 AM
  #133
sl55 amg
i was just looking at headlights right now. do you have pics of the other kit you are looking at?
misha's holiday deal right now is really good! by the time i sell off all my stock stuff and figured at low sale prices, i will only have a split of $2k and that counts the new headlights in!!! it should only take a week or so to install it. the rest of the car is perfect, so it will only take a light scuff and go right to paint.
Old Dec 15, 2012 | 12:23 AM
  #134
kustom2k1's Avatar
03SL55
Sent you PM
Old Dec 16, 2012 | 09:33 PM
  #135
sl55 amg
i have a set of 19x10 and 20x12 adv05.1's on my 67 camaro. i think i am going to rob them from that project and use them for the widebody sl kit. by my figures the offset should work with a 1" wheel adapter (gotta go from mercedes to chevy bp). i think the wheels will look alot better on the sl than the camaro. sell my current wheels then and buy new wheels for the camaro that will fit that project better.
now if i could just make up my mind on a kit!!! i'm down to 3.
Old Dec 16, 2012 | 09:35 PM
  #136
RaFFi ///AMG's Avatar
W124 E500 (RIP), W211 E350 (Sold), R230 SL55 (Current)
I think the 19" in the front is gonna be way too small for a widebody.
Old Dec 16, 2012 | 10:16 PM
  #137
sl55 amg
the original black series were 19" front and 20 rear, so it should look fine. i can always just get spacers for my current wheels too that are 20x9 and 20x11.
Old Dec 17, 2012 | 03:24 AM
  #138
amok55amg's Avatar
This is the cheapest I ever found on new headlights: http://www.ebay.com/itm/160873854473...DXX:IT&vxp=mtr
OverZealous1 - could you please give a short crash-curse on fuel-pipe and injectors? Cal1 says he needs them since he's almost 500 hp at the wheel and this is a must to prevent the engine to blow up
Old Dec 17, 2012 | 12:49 PM
  #139
sl55 amg
the fuel rail mod is pretty easy. there is lots of pics as to where to cut the rails, then just butt weld on a pair of 6an fittings. a couple of 90 degree 6an fittings off of that and route crossover tube under blower. the crossover tube is very tight though, best to do the fitting of it with blower off.
injectors are a no brainer, but depending on the style of injector you will need to use ev6 to ev1 adapters.
Old Dec 17, 2012 | 02:58 PM
  #140
sl55 amg
the descision has been made!! very shortly will be joining the misha body kitted sl family!!
Old Dec 17, 2012 | 05:44 PM
  #141
kustom2k1's Avatar
03SL55
Heads up....thericker is selling a set of rims for this setup. Just in case Ekselent doesn't want them..
https://mbworld.org/forums/5472426-post11.html
Old Dec 17, 2012 | 06:02 PM
  #142
sl55 amg
pm sent to thericker!
Old Dec 18, 2012 | 01:32 AM
  #143
sl55 amg
i really have a problem painting every car blue, or orange. i can't help but think this color might look killer with the misha kit. black wheels etc and this blue. simple, easy to match/repair, easy to spray, and i think will give great lines to the car with a racy, old school, and new school look.
Old Dec 18, 2012 | 01:38 AM
  #144
sl55 amg
or the 370z blue. all i know is i want a straight tone and no pearls or metallics. every paint i have done has had effect, would be nice to just do a straight tone. want to compliment the lines instead of over powering. if that makes sense.
Old Dec 18, 2012 | 01:52 AM
  #145
sl55 amg
jesus!
Old Dec 18, 2012 | 02:32 AM
  #146
amok55amg's Avatar
hmmmm - overZealous1 - I have been searching this Forum and the E63 etc. for this fuel rack conversion ..... I do understand how to do it etc. - no prop. but the WHY thats what Im' trying to understand - whats the need and the benefits for this conversion? ..... I'm back on the school bench here and appreciate all the help I can get .... to get me on the right track so to speak
Also; did you change your spark plugs?
Old Dec 18, 2012 | 11:52 AM
  #147
sl55 amg
no prob. because of where the fuel inlet to the rail is, and the shape of the rail being somewhat of a horse shoe, the furthest away injector lacks in fuel delivery and pressure. looping the fuel rail aids in equalizing pressure to all injectors.
i saw alot of melted pistons and blown motors in threads being blamed for this. the best option is doing a return style fuel system. but, that would require redoing your fuel system nearly in its entirety.
Old Dec 19, 2012 | 10:31 PM
  #148
sl55 amg
tons of research is paying off. found a used nearly perfect headlight for $575, and 2 ballasts for $198. just one headlight to go!!
Old Dec 19, 2012 | 10:32 PM
  #149
sl55 amg
i will update as to just exactly how many beers it takes to install long tube headers on just jack stands. it will be alot!
Old Dec 19, 2012 | 10:44 PM
  #150
kustom2k1's Avatar
03SL55
I say many. I'll keep my ears to the ground, which side headlight do you need?
You have already rated this thread Rating: Thread Rating: 22 votes, 5.00 average.
