SL55/63/65/R230 AMG: Maintenance questions - How To's?
Wanted to change and flush the ABC fluid/Filter so I've purchased the filter/seal/spring and about 12L of CHF11S fluid.
Is there a DIY guide somewhere on this forum? I can't seem to find it through search.
I know it'll involve a Rodeo, just hoping to change everything myself first before I bring it into a mechanic for the Rodeo part.
Cheers and thanks in advance!
only filtering it with a new filter is now recommended in case of sagging of vehicle over night (and sagging is rarely if ever fixed by filtering the fluid).
this how it goes: (you need to purchase two abc filters) and do it when the abc filter is warm.
1. replace old filter with new filter
2. rodeo twice
3. replace new dirty filter with the second new filter
you are done.
buy another filter, do the procedure above and keep the pentosin for the time when you are going to leave the current one spilled on the floor
12.99 each x 16
Free Shipping
Fatwallet 4% cashback
and coupon codes http://www.fatwallet.com/Advance-Auto-Parts-coupons/
Hope that helps somebody.
Cheers
the spring does not need to be replaced.
btw, make sure you are buying the new finer mesh filters ( i forget the actual microns) . if you are buying from an authorized mercedes dealer he will provide you with the new one by default. if you are buying from another source- make sure you get the updated part.
Aaron
12.99 each x 16
Free Shipping
Is there a write up on changing plugs (do's / don'ts) in the SL55 somewhere ??
Wondering what else I can buy using those codes.. lol
