SL55/63/65/R230 AMG: Slower than E39 M5?
Old Jul 27, 2013 | 09:02 AM
JadAwada's Avatar
SL55 AMG
Unhappy Slower than E39 M5?
Hey mates,
A guy that owns an E39 M5 asked to race with me, I said its ok just to know how much can my SL55 go beyond such an M5. The result was disappointing, that guy was able to beat me with almost a car ahead.
I have bad wheels, and my transmission is leaking oil. However, I don't think that will make that different.. I thought I should beat him with like 5-9 meters difference.
What do you think this would be?
Note: I had injector cleaner in the fuel tank.
Old Jul 27, 2013 | 09:34 AM
Welwynnick's Avatar
2006 S600
Something's wrong. Is your IC pump working OK?
Nick
Old Jul 27, 2013 | 10:29 AM
JadAwada's Avatar
SL55 AMG
Thanks for the help Welwynnick, I have no idea, I only own this SL55 since two weeks.. Should the IC pump give an error on the scanner? Monday I'm going to the workshop.
Old Jul 27, 2013 | 01:06 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Not always but it's safe to assume you need a new one based on your results. There are some much less expensive pumps on the market. The dealer is going to really sock it to you on a replacement pump. Do a search on the forum to find a less expensive alternative.
Old Jul 27, 2013 | 05:18 PM
Welwynnick's Avatar
2006 S600
Just don't get a Johnson CM30. A proper Bosch pump isn't expensive.
Nick
Old Jul 27, 2013 | 06:36 PM
alx's Avatar
alx
You should be much faster than a stock e39 m5.
As others said- check your ic pump.
Old Jul 27, 2013 | 06:39 PM
pdjv's Avatar
2011 E550, 2008 SL55 AMG
Er, have you considered the E39 M5 might not have been stock and the driver was just looking for easy prey?
Old Jul 27, 2013 | 11:10 PM
RaFFi ///AMG's Avatar
W124 E500 (RIP), W211 E350 (Sold), R230 SL55 (Current)
I owned an E39 M5 right before my SL. The SL would run laps around the M5. Check your pump.
Old Jul 29, 2013 | 12:35 PM
sound 8's Avatar
SL 63 W/B AMG , S600,C220
Don't worry all is normal. My SL55 was stock, and rather disappointing
speed wise. An M5 would beat it, I know one beat me
However you can tune the 55 to about 570 bhp I was told.
Old Jul 29, 2013 | 12:38 PM
JadAwada's Avatar
SL55 AMG
No sound8, I just tested my car today, and the workshop said it needs a MAP Sensor, and the transmission needed 4L of transmission fluid, so it was slipping. So the result was normal, however the M5 driver told me yesterday he had a MAP and pulleys, so his car is 450 HP.. yet I can beat him as soon as I replace the MAP sensor, and spark plugs
Old Jul 31, 2013 | 09:24 AM
sound 8's Avatar
Well Jadawada, with a duff MAF and all that transmission oil missing I am
surprised you didn't have a problem overtaking a 518 Beemer,
Old Aug 1, 2013 | 01:50 AM
LukasBMW's Avatar
2025 BMW I4, 2018 Alfa Romeo Giulia Quadrifoglio, 2008 ML550
450hp in a 3900 lb car VS. 500hp in a 4,400 lb car
Stock the M5 runs low 13's in the 1/4. (Modded is probably high 12's)
Stock the SL55 runs mid- high 12's in the 1/4.
The driver could easily make the difference. Small issues with the car could make the difference as well.
Old Aug 1, 2013 | 04:19 AM
E39 m5 is 400hp. Curb weight of 4k pounds. Trust me I've owned both, and there is no comparison.
Old Aug 2, 2013 | 12:02 AM
LukasBMW's Avatar
I listed the 450hp figure because the poster said the e39 M5 he raced was modded. My buddy had an 00 M5 that tipped the scales at 3950.
I agree the SL should be faster and it DEFINITELY *feels* WAYYYY faster due to the torque difference, but in this particular example, I think the difference could be due to the driver and mods.
Old Aug 2, 2013 | 09:21 AM
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
no comparison even when an e39 m5 is moded, it will get rapped.
as others have said IC pump needs updating to the newest one. it iwll not show a fault code when they go bad
