SL55/63/65/R230 AMG: ABC Hose going out?
Hi Guys,
Couple weeks ago I started the car and had a drip drip under my driver side wheel well. The stains it left was a ring stain.
After driving for 30 minutes it went away and it's been weeks since it dripped. I assumed it was a weeping hose
I took it to the dealer and they said they couldn't find the hose leaking and said it was spot free
Here's the video clip and picture, has anyone seen this before?
Hi Guys,
https://youtu.be/plkb5hri-JY
https://youtu.be/lUZ12--jeZA
hope that helps,
Chris
Next thing is to look for a reservoir that is dropping level.
Then take the wheel and wheel arch liner off and get a good torch.
Since it's dripping you're going to have to do something about it quite quickly.
Nick
I know when it hit the water since it was wet outside it caused that ring stain shape. Almost looks like FUEL! There was no smell though!
hope that helps,
Chris
What does MB call it.
Car drives perfectly and no leaks or stains as MB puts it..mystery to me.
Either way this is interesting.
https://mbworld.org/forums/sl55-amg-...ml#post6160699
worth noting, later R230s (late 2006 and on?) moved one of these up to the ABC pump
hope that helps,
Chris
hope that helps,
Chris
A guy makes a video in the middle of what the symptoms are
Thanks, sounds like this. But I don't have any lights or burps...I'm leaning on hose behind the wheel well.
MB didn't find anything either..they said no oil at all there..!
Phantom mystery at this point...Resovior looked clean and no residue anything, levels fine according to MB and Euro shop now.
I'll stay on the lookout.
