SL55/63/65/R230 AMG: New engine/trans mounts on Nay's SL55
2016 S63, 2013 SL63
70k miles on her 2005 and it felt like a drive shaft was wonky. 800.00 in labor and I bought the recommended mounts from RockAuto.com.
Feels so much better!!
![](https://staticssl.ibsrv.net/autocomm/EvoM/fcotmicon.gif)
I had a balance issue that I could not determine. I also thought it was tire balance. After balancing the tires with no luck, a fellow member here told me to have the trans serviced, even though not a bunch of miles since last service (maybe 20k miles?). Voila! - no more vibration.
140-277-00-95 Filter
140-271-00-80 Elastomer - MO
140-271-00-60 Seal Ring
140-991-00-55 Lock pin
Q-1-09-0166 Mobil ATF134 Fluid
This is just a thought - this may not be the case in your instance.
Prior to this, I had tires balanced, 4 wheel alignment performed.
