SL55/63/65/R230 AMG: Source and p/n for ABC Shutoff Valves?
So my next step is to replace the valve. Rather than a shot gun approach with a used valve, I'm hoping to find one from a source that tests them. Needn't be a new part, but overhauled and tested if I can find one.
Any known sources? Does anyone know the part number? Or maybe someone in the community has one of known condition to sell me? PM please.
Thanks,
MK19
I did find a source on eBay "vtrading916" in CA. He has a great rating. He offers a valve block rebuild service at the following link but agreed to sell me SOV's too.
Now I'm wondering about the interaction between the corners and the front/rear? I've been focused on the RR, but am now considering that if the RF droops, then it must be lifting the LR thus making the LR/RR height different greater leading me to think the RR valve is leaking.
Is there a known troubleshooting procedures/suggestions??
Thanks,
MK
Both great suggestions.
I have changed the rear seals, but not yet the front (soon thought).
Your points about the blocking valves not closing right after the ignition is turned off is consistent with my observation that the car seems to drop a bit (maybe 1") when the ignition is turned off. So I gather that's when its leveling up or trying too.
However, after hunting for the solution to a CEL yesterday (See post re code P202B-002) the car is near level from an overnight rest with all wheel arch measurements within 1/4" or less. So I'll cross my fingers with hopes that things are now stable. If not that might indicate bad seals up front as I'd think that those leaks can be more erratic that the blocking valve leak in a clean system with 2-3 micron filtration. But I'll watch and see if after I turn off the engine and it settles in, and in particular to see if at that moment its level (I think I've done this before and found it was level). If not it would it suggest a bad control valve, or a bad seal at a control valve (probably more likely).
If it goes to far I'll have both valve blocks overhauled by the source noted above - pretty inexpensive really.
More to follow.
In fact I asked this eBay seller if his valves were tested and his reply was that, as you suggested, he checked the resistance and resealed them, but that "they could only be tested in the car". That of latter bit is of course makes his valves a crap shoot no better than buying from a dismantler. Being a long time aero hydraulics engineer, I know the latter to be false. Of course they can be tested, but testing requires a test rig (Pump, filter, reservoir etc.) and one needs at least some pass/fail specs. And a simple leak test can be conducted using compressed air, one would need to know what pressure to apply, and with air we'd be limited to lower pressures, but lower pressure puts less closing force on the poppet and would probably result in exaggerated leak rates on a bad valve. With a air pressured test you'd want some fluid at the valve sealing interface, and then a drip tube on the downstream side. Leakage is typically measured in drops per minute (something like 15 drops per cc, depending on fluid characteristics). Maybe I ought to go into the business??
I'm still experiencing sagging that's most prominent in the RR, about 1 to 1.5" difference left to right after an overnight rest. Not all that sure where I'm headed next not that I don't have a source of tested SO valves? Could I be looking at the wrong valve? I've been focused on the Red dot valve for the RR.
