SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: New SLK owner - 1st 2 questions
Old Sep 15, 2006 | 07:48 PM
WB9AXO's Avatar
'98 SLK230, '84 VF1100S
Talking New SLK owner - 1st 2 questions
Greetings fellow SLKers
I recently purchased (on eBay!!) a 1998 SLK230, 81000 miles for 13.5K (+ship from Fla to Indy). I'm very happy to find this list and hope to gleen all sorts of information from its' members. And maybe one day, I'll have advice to offer back.
After having my requisite 'Service A' at the local "discount" MB shop for $200, and paying $300 to have my 2 belts replaced, I've come to the conclusion that I will need to do a few of the things this otherwise very fun car needs.
To that end, two items for the assenbled brain trust with thanks in advance for your collective wisdom.
1. The shop wanted $180 to replace a dash light bulb specifically the one that illuminates the fan switch and drivers temperature wheel. Can it really be THAT difficult? I'd appreciate advice on how to get at that part of the dash to replace this $1 bulb.
2. I was informed that my front brakes are down to 5% and the rotors should be replaced. It seems to me with a floor jack, the correct replacement rotors & pads and an a couple of hours one weekend afternoon, I can do this myself, no?
I should tell you that I'm not a 'wrench monkey' but I do most of the maintenence on my '84 Honda VF1100 motorcycle, so I'm not afriad to save a buck or two (hundred).
Again, thanks for letting me join your club. I look forward to your suggestions.
Cheers,
Chris
Old Sep 16, 2006 | 06:47 AM
bazzle's Avatar
Fan knob light 5 minutes
http://www.benzworld.org/forums/r170...eater-fan.html
Brakes , when I did mine
http://www.benzworld.org/forums/r170...rs-repost.html
Bazzle
Old Sep 16, 2006 | 10:58 AM
WB9AXO's Avatar
Originally Posted by bazzle
Bazzle, you are my new best friend. Thanks mate!!
Old Sep 16, 2006 | 09:42 PM
contractsguy's Avatar
99 SLK 230 - US Model
I've had my SLK for over a year now and found the local dealer here in Virginia to be EXTREMELY high in their repair costs. I guess they assume if you can afford a Mercedes you have money to waste and you are stupid because you are willing to pay so much.
Can't offer any advice on the bulb, but the brakes are extremely easy to replace. The only problem I had with my 1999 model was that the brake disk mated, via rust, to the front hub. It took a special chemical to remove the rust, but the rest of the brake replacement process was very easy.
Where possible I'd suggest you purchase your parts from vendors on the internet; there are a large number of OEM vendors.
Good luck!
Old Sep 16, 2006 | 10:49 PM
WB9AXO's Avatar
As per Bazzle's post, the fan switch pulls off revealing the tiny bulb which I removed with needle nose pliers. The replacement bulb (2 for $3.99 at Autozone) pops right in. Push the knob back on and you're done. Less than 5 minutes, less than 5 bucks.
I'll be installing Brembo discs from DRT and Porterfield R4-S pads in the near future with a little help from a buddy that has experience. I haven't done much work on a car since high school back in the 70's.
Cheers,
Chris
Old Sep 17, 2006 | 10:24 AM
page62's Avatar
Don't worry. These cars are actually easier than most to work on! Brakes are easy -- it's mostly a plug 'n play operation. Just follow Bazzle's procedure.
But first, you should actually check the brakes for yourself. Unless they're heavily scored, the rotors may not even need replacing. And who knows how much pad thickness is actually left? (I guess I'm from Missouri at heart: "Show me." Then I'll believe it.)
(I won't tell you how easy the belts are, because it would hurt too much...)
Old Sep 17, 2006 | 10:40 AM
WB9AXO's Avatar
Thanks page62
Well, if I had discovered these forums (MBWorld & BenzWorld) sooner, I would've done the belts myself. Back in the day I changed the serpentine belt on my '79 Mustang 5.0 in about 5 minutes. I just assumed it would be much harder on this car. Obviously that assumtion cost me $300!!
As far as the brakes go, the mechanic pointed out a rather distinct ridge around the edge of the rotor surface and said new pads alone would just get "chewed up real fast".
Cheers,
Chris
1998 SLK230
1984 VF1100S
Old Sep 17, 2006 | 11:53 AM
page62's Avatar
Someone's trying to make a sale.
All rotors do that. The ridge is the portion of the rotor where the pads don't touch it. Therefore, that portion does not wear, while the rest of the rotor surface wears down. And the next set of pads won't touch that portion either. Ergo, no chewed up brake pads.
Check on this with Bruce R. over on the other forum. He's very knowledgable about brakes.
Old Sep 17, 2006 | 11:55 AM
70chevelle396's Avatar
2001 SLK 320 , 1970 Chevelle SS
It sounds like the rotors are worn. Just replace them, they are about $50 A piece. You also need the brake sensors. Get the right brake pads, not the ceramic ones. Ceramic pads tear the rotors up faster.
Ken
Old Sep 17, 2006 | 06:14 PM
DesignoSLK's Avatar
'07 SL55 AMG, '00/'04 SLK230 Designo Copper, '18 GMC Acadia Denali AWD
Originally Posted by contractsguy
It took a special chemical to remove the rust...
Beer 2 weekends in a row right?
Old Sep 17, 2006 | 07:27 PM
WB9AXO's Avatar
With 82000 miles on the car, I think I'll start with fresh pads and rotors. What I spend on rotors I'll save on labor
Old Sep 20, 2006 | 01:51 PM
DesignoSLK's Avatar
Oops...contractsguy...I may have confused you with TheJimbo...sorry.
Old Sep 20, 2006 | 02:27 PM
TheJimbo's Avatar
2001 SLK230
Yep, that would be me. If ever I run into an unexpected issue with the SLK, I merely throw the marinated steak on the grill and pop open a brewskie. The problem ususally goes away on it's own after this procedure is repeated several times.
Old Sep 20, 2006 | 03:13 PM
DesignoSLK's Avatar
