SLK/R170: Loose exhaust? Or other problem? Please help.
2001 SLK 320
There seems to be a loud rattling sound that seems to come from under the car. Someone had a similar noise coming from a BMW and they told me it was a loose exhaust, but when I get under the car (no small task), everything looks real tight.
Any ideas? Just hoping to get an idea of what the repair bill will be, or if I might be able to remedy the problem myself.
It's probably a lose heat shield. Get under it and shake any heat shield and see if they wobble. I doubt it's the cat, if it got to the point where it's insides would rattle, it would likely be clogged and you would notice a drop in performance and/or rotten egg smell in the exhaust. It could be a lose exhaust but if it's that lose it may be corroded.
I had a rattling noise, but only for a few seconds in the morning, when I would crank up. It took me awhile, but I finally figured out it was a heat sheild, right over the muffler. I had it pushed back about 2mm, that's all. Problem solved.
2001 SLK 320
Thanks for the suggestions. I'm gonna see if I can get under it. I sit really low so it’s hard as hell to get under. I'm thinking its a heat shield, with all the bumps and as low as I sit I probably knocked one loose.
One trick I've used over the years, comes in handy when evaluating a used car purchase is to drive one side of the car, 2 wheels on curb, taller the better and make sure parking brake is on real good. Gives you a few more inches to crawl under.
2001 SLK 320
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
Well I just found out. It is my catalytic converter
My mechanic wanted to charge me $1,000.00+. Luckily I'm covered under warranty. Going to take it to American Service Center and pray they don't find some way out of the Warranty. I'll let you all know.
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
my converter went bad on a cross country trip. Started with a sound like a rock was in the heat shield and got worse. Stopped by the Albuquerque Mercedes dealer and they had the part send overnight so I could be on my way. The Las Vegas dealer would not even look at the car for a week, even though they knew I was on the road. All costs were covered, without a problem.
2001 SLK 320
Yeah. I got my car fixed at American Service Center in Arlington Va. People were nice and I got it fixed in a few hours. I was exepecting to be without my ride for a few days. Quick, easy, and free. Can't complain.
