SLK-Class (R171) 2004-2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
SLK/R171: Oil change???
Old 09-29-2005, 09:34 AM
Mojo1's Avatar
2005 SLK350 BLACK (HERS) 2004 C5(MINE)
Oil change???
I have not looked underneath real good yet but I am planning on changing oil in this weekend.Any tips or tricks I might need to know ? I just llike doing things like this on my cars,I picked up 2 filters and they are not the screw on type.Also would like to get service manuals if any one knows where I can ????
Old 09-29-2005, 12:31 PM
Ynot's Avatar
MBZ SLK
Here are some pics on how to do it, for more details do a search for oil change on benzworld.org. Search for a thread started by fgwinn
http://www.benzworld.org/gallery/sho...R171_SLK_Class
Old 09-29-2005, 01:28 PM
Mojo1's Avatar
Thanks ,do I need to buy the tool to remove the filter?
Old 09-29-2005, 02:58 PM
Ynot's Avatar
MBZ SLK
I'm not sure as I haven't done it myself, my SLK only has 1200 miles on it, PM fgwinn, he has done it and have all the details.
Old 09-29-2005, 03:38 PM
Mojo1's Avatar
PM sent ,thanks again
Old 09-29-2005, 04:10 PM
Ynot's Avatar
MBZ SLK
Here you go,
http://www.benzworld.org/forums/foru...211655&posts=6
Old 09-29-2005, 05:35 PM
Mojo1's Avatar
Thats the ticket thanks so much for your help!
Old 09-29-2005, 05:45 PM
mtimmy's Avatar
W208 55 & R170 230
I thought Mercedes dealers no longer change oil from the bottom right...?
they use vacum pump to suck oil from the top...
Old 09-29-2005, 07:39 PM
Ynot's Avatar
MBZ SLK
Old 09-29-2005, 07:40 PM
Ynot's Avatar
MBZ SLK
Possibly, this is done by a member of the forum, not MB, the dealers could possibly use the vacuum pump method.
Old 09-30-2005, 07:02 AM
LAZARU5's Avatar
EQS 450 4Matic SUV
Mityvac fluid evacuator
While you can change the oil by draining it from the bottom of the engine, it's not particularly easy on the R171, especially if you have the SLK350 w/AMG Package. The problem is that typical auto ramps won't fit under the front bumper (although Rhino plastic ramps will work with standard bumper).
Since the drain plug is towards the back, you will probably get most of the oil drained, even if the car is at an angle on the ramps.
The first time I drained the oil, I went thru great pains to raise the car on all four corners so that it was level when I removed the oil. The reason I wanted the car to be level is that I wanted to check the dipstick level after adding 5, 6, 7, 8, and 8.5 quarts.
You can find a Mityvac fluid evacuator online for about $75 for the air operated model and a few dollars less for the one with the manual pump. I use the one with 8.8 liter capacity. I attached the largest diameter tube supplied with the Mityvac to the top of the dipstick tube with a rubber stopper (w/hole in it). The dipstick tube in effect becomes an extension of the Mityvac tube. It takes about 5 minutes to extract 7 liters. I then inserted the smallest Mityvac tube down to the bottom of the dipstick tube to extract the last liter.
Just to be absolutely certain that I evacutated all of the oil, I removed the drain plug. I was surprised to see that only enough oil drained to make a small puddle of oil about 4 inches in diameter on the bottom of the oil drain pan. Mityvac extractors work very well.
The cost of the extractor is paid for in the first oil change unless your dealer happens to be running an oil change special discount.
I don't plan to drain the oil from the drain plug in the future unless I come up unreasonably short when I use the evacuator.
Hope this info helps.
Old 09-30-2005, 11:26 AM
Mojo1's Avatar
Helps alot and thanks. I have some ramps I made to use with the Vette that will work on the MB ,I dont have the AMG package though. I might invest in the oil evacuator .Thansk Fgwinn
edit: is this the pump? Fluid Evacuator Plus 7201 - 8.8 Liter
or here for a little cheaper . http://www.sjdiscounttools.com/mit7201.html
Old 09-30-2005, 10:56 PM
LAZARU5's Avatar
EQS 450 4Matic SUV
That's the unit with the hand operated pump. I got the next model up that requires an air compressor to operate. I find that I am able to transport the full Mityvac to Autozone or Advanced Auto to recyle the oil.
Old 10-08-2005, 10:41 AM
Mojo1's Avatar
I used the pump today ,thing worked great ! I should have got the air one but never did see it on the site but it wasnt to bad doing it by hand.I will use it to do my car also but will have to jack it up to get to the fileter were as before I had to drive it up on ramps then jack the back to get it level.Thanks for the advice ! Also bought the filter remover tool from the dealer and it was only $25.00 !
Quick Reply: SLK/R171: Oil change???
