SLR/C199/R199/Z199: Help with SLR Noise
I have 2006 SLR that make a noise when I have the ESP off and pull a hole shot.There is no noise other then the tires spinning when step on it. But as soon as you step out of it. It sound like a belt slipping.
MB is telling me that this is normal.
Thanks for any Info
Rick (Mclaren SLR)
Thanks for any Info
Rick (Mclaren SLR)
That said, lambopower.com has a section called SLR-Power. There is an active forum there with several SLR owners, myself included.
Try posting there for some info. Good luck.
it only happen with the traction control off and when u do a serious burnout. its like a high pitched squeal correct?
porter dont u get that on urs?
Yep That it.
But only when you get off the gas
Rick
front, back, inside, etc etc.
I know tis sounds odd but a lot of the squealing noises on SLR's comes from the ESP/SBC pump and lines, Usually performing the "air release" procedure in SBC will eliminate a lot of weird noises.
If you where a little closer, I would do it for you!!
