Mark this thread as Sold
FS: K-Mac adjustable rear toe bushings
Old Dec 23, 2010 | 11:24 AM
AMGDave's Avatar
300D, 500E, E420
Several years ago I installed K-Mac kits on two of my cars. On the one car I installed the full kit (camber + toe bushings), on the other car I installed the camber bushings only. I eventually removed the kits from both cars due to the squeaking noise from the polyurethane bushings; while it wasn't audible from inside the car with the windows up, I would hear it at low speeds with the windows down (i.e., going over speed bumps in a parking lot). I switched to the RDM TEK solution instead for rear camber correction.
However, I did learn that with any rear camber correction kit, you will run out of rear toe adjustment if the car is at all lowered (and even a stock 500E may be borderline, right at the limit of rear toe adjustment). That's why K-Mac included the adjustable toe bushings with their camber kit. I have since sold all the used bushings, but I still have the new, unused toe bushings available. They would be a perfect complement for the RDM TEK kit, or any other type of rear camber correction kit you may have installed. Photos are below.
For price reference - the complete K-Mac kit sells for about $320 (camber + toe) , and the factory rubber eccentric bushings which also allow extra toe adjustment are $354/pair MSRP (toe only, not camber!). These bushings are half of K-Mac kit #502026 and will work with the following chassis:
124, 129, 170, 201, 202, 203, 208, 209, 210
$150 / obo, free shipping in USA, PayPal ok.
Old Dec 25, 2010 | 11:24 PM
suicidal4life's Avatar
2001 E430
Emailing you
Old Dec 28, 2010 | 12:09 AM
Leeward's Avatar
220SE
We also experienced this squeaking, but found that it was a matter of having to get the bolts tight and keep them that way.
Problem was that the early kits had Nyloc nuts and these are a one-use thing. We just tightened them and put an extra nut on the outside as a locknut. We had correspondence with K-Mac at the time and they now supply double length nuts for these kits with a separate anti-rotation twin lock washer.
Squeaking is a thing of the past.
Old Dec 29, 2010 | 12:08 AM
2001 E430
Just saw your email. I'll take em.
Old Dec 30, 2010 | 12:09 AM
2001 E430
Payment sent. Thanks
Old Jan 3, 2011 | 10:16 PM
2001 E430
Arrived today. Thanks!!
Old Jan 4, 2011 | 10:05 AM
AMGDave's Avatar
300D, 500E, E420
Cool - glad they arrived safely. Enjoy!
Old Jul 15, 2011 | 02:05 PM
AMGDave's Avatar
300D, 500E, E420
Closing thread - forgot to do that before, ooops.
