.......Answer: YES!.
.......engine rebuild with sleeving of all 8 cylinders, Carillo rods and low compression pistons, 8.5:1 compression ratio.
........Kleemann s/c with * rib 60mm s/c pulley
........14% overdrive 8 rib ASP crank pulley. https://www.aspracing.com/ezRetail/s...php?msg_id=394
.....custom 8 rib Kleemann s/c pulley, 8 rib aluminum alternator pulley, 8 rib power steering pulley, smooth idler pulley, 8 rib belt tensioner.
........Biggest problem...........there is no 8 rib ac compressor pulley for W210 or W208 or W209. Problem solved! Custom 8 rib ac compressors for W210 and W208 and W209. Pics below.
.........Result. 8.5:1 compression, 16lbs of boost Kleemann s/ced W210. I need tires!!!!!
Ted,
Any downside to this? I'm guessing you're running 16lbs of boost now? Where can we get the custom 8 rib ac compressors for W210? PM me if you like. This is good news indeed!
.........Yes, I am running 16LBS of boost now. Drove the car like I stole it for four days after project completion. No issues. Because of the overdrive at the crank, the power steering is much easier to turn. Not an issue to me, but some might describe it as less feedback from the steering wheel. Originally Posted by JamE55
Ted,Any downside to this? I'm guessing you're running 16lbs of boost now? Where can we get the custom 8 rib ac compressors for W210? PM me if you like. This is good news indeed!
.........In order to convince the company to make the a/c compressors, I had to purchase five of them. I have 3 left. Anyone can have them for $1500 each. This is basically the same price as an oem 6 rib a/c compressor from the dealer. Reason to go to 8 rib system is that that the stock 6 rib system cannot handle the boost and results in belt shreading.
Ted
Thanks Ted. Need to save up some money for that. Just bought a complete CF kit so money is tight. So by buying that compressor kit is that all i would need or do i need to get the pulley as well? How long did the insallation take?
Quote:
............the ac compressor is a direct swap. You will be getting the entire compressor with the pulley already in place. You can then sell yours if you wish.Originally Posted by JamE55
.........The ac compressor is the most difficult part of part. To go from 6-rib to 8 rib, you would need to swap all your pullies to 8 rib pullies. Any machine shop can make you 8 rib versions of the other pullies but not the ac compressor.
Ted
Ted, any dyno numbers yet to share with us? Would I run into problems if I switched to the 8 rib pulley's without the engine rebuild as you described?
Wondering how much boost I would gain? Currently running kleemann s/c 65mm pulley custom built when donnie installed....so is the 8 rib 60mm available from Kleemann or did a machine shop make the s/c pulley with the remaining pulleys? If no problems would arise, I may be interested in your 8 rib ac compressor. I want that feeling of stealing something, the adrenaline is addictive. Thanks.
Wondering how much boost I would gain? Currently running kleemann s/c 65mm pulley custom built when donnie installed....so is the 8 rib 60mm available from Kleemann or did a machine shop make the s/c pulley with the remaining pulleys? If no problems would arise, I may be interested in your 8 rib ac compressor. I want that feeling of stealing something, the adrenaline is addictive. Thanks.Former Vendor of MBWorld
Quote:
Originally Posted by Ted Baldwin
.........In order to convince the company to make the a/c compressors, I had to purchase five of them. I have 3 left....
You are a true gearhead, sir.
Congrats on completion of the project.
ExploreOut Of Control!!
very nice project Ted
are you running the same boost on the g55 as well or just one at a time for now?
very impressive though, sound of that must be pretty loud too
...........Everything was custom made. You probably should not increase your boost without lowering your compression.Originally Posted by 4runner
........No dyno numbers yet. I am currently in Florida. I flew down to Atlanta last week to test drive the car for four days. It was fantastic. My car ran a best et 0f 11.8secs well before I started these mods. I am actually not sure that the car will be officially faster due to traction issues. I suppose I'm intellectually pleased that I was able to do it. You have no idea how many were unwilling to listen as I tried to explain what I wanted to do. I wish I was a mechanic. I am good at thinking up things, researching them to make sure that they are feasible, but I cannot do the job myslef. Finding a mechanic to listen is difficult. I don't really blame them, though.
Ted
I applaud your drive to push the envelope! How did you deal with fuel and tuning?Member
Ted
Ted, I am in the same boat, finding a mechanic knowledgeable in my area (South Louisiana) is nearly impossible, heck the town that I live in, I have only seen 3 other cars that are MB. It appears that to enhance the power out of this beast and push the envelope, I'll have to ship the car to a reputable mechanic. Even if I knew a little, finding the time to actually do it is impossible. I may have to look into a mechanic willing and most importantly able to do this work...maybe I'll speak to donnie soon and get recommendations. By the way...your car is beautiful and very stylish done with excellent taste I may add, I suppose some of us have that passion and love for the W210 E55Originally Posted by Ted Baldwin
...........Everything was custom made. You probably should not increase your boost without lowering your compression.........No dyno numbers yet. I am currently in Florida. I flew down to Atlanta last week to test drive the car for four days. It was fantastic. My car ran a best et 0f 11.8secs well before I started these mods. I am actually not sure that the car will be officially faster due to traction issues. I suppose I'm intellectually pleased that I was able to do it. You have no idea how many were unwilling to listen as I tried to explain what I wanted to do. I wish I was a mechanic. I am good at thinking up things, researching them to make sure that they are feasible, but I cannot do the job myslef. Finding a mechanic to listen is difficult. I don't really blame them, though.
Ted
...........I'm using the stock Kleemann tune for S7's.Originally Posted by blackbenzz
Ted
Quote:
Sounds like a real beast.
Mechanics can be real knuckleheads
Lona
.............thanks.Originally Posted by Lona43
Ted, Sounds like a real beast.
. Lona
Ted
Awesome project! Just out of curiosity how much boost are the modded W211's running? I'm feeling lazy and don't want to search.
Quote:
............it depends on the size of the crank pulley. Various vendors have different size crank pullies giving different ammounts of boost. Stock boost is about 13 or so. With the ASP pulley, boost can go up to 16LBS. Originally Posted by suicidal4life
.........The design of the W211 is a bit different. There are two belts. A 6 rib belt and an 8 rib belt. The 6 rib belt runs the accessories. The 8 rib belt runs the crank and connects to the s/c pulley. This allows you to increase your boost without overdriving your accessories. Notice also that Mb chose to use an 8 rib instead of a 6 rib belt for the crank and s/c, because they are high boost applications. Same in the C32. This belt upgrade is frquently done by owners of other makes and models during high boost supercharger installation. In those instances the pullies are readily available off the shelf from various vendors. As far as I know, this is the first high boost aftermarket s/c in a Mercedes. You may have heard of the Renntech "high boost s/c, " but the boost is about 8lbs.
Ted
When are we gonna see a 10s time slip Ted?
Fastest mercedes off nitrous?
.........At 11.4 secs et in your CLK55, you are much closer to 10secs than I am at 11.8secs. 10secs is not in the cards for my car. At 11.8, it was already the second fastest W210 next to Jim Cannon's car. So I'm pretty happy with it. The recent mods came about as a matter of necessity. At first I wanted to go twin turbo, but I decided against it. My engine was already rebuilt with lower compression which will make it slower if the boost was not increased. There were no larger crank pullies for W210, so I decided to use the ASP pulley designed for the C32. This resulted in too much boost which then resulted in belt shreading which then resulted in the belt upgrade which luckily has worked out beautifully.Originally Posted by blackbenzz
.........I now have a better appreciation for the importance of chasis design. My car is so outrageous currently that I do not see how it can be any faster. Everything just goes towards tire shreading. The w210 chasis was definitely not intended to have done to it what I and others have done to it, but it sure is fun!
Ted
Did you get a chance to take it to the dragstrip or dyno? I'm still in awe
Ted when you get your E55 back in FL you need to bring it out to one of the events at Tower Shops in Davie or EuroStage 1st Sunday of the month. I will like to see it in person.
Quote:
I'm pretty sure he already has an LSD.Originally Posted by thebenzbar
Traction issues?... Quaife time??
Wow, even with an LSD that beast must be a tire melter! I'd love to see videos of it doing passes on a strip!
