Anyone crack their motor mounts?
I just got a message from my dealer, cracked motor mounts!?!?!?! Anyone else crack their mounts at 40k miles? Oh yeah, he said the way you drive expect them to go in another 40k miles? Now I used to launch my 11sec mustang at 6000rpm, carry the wheels and never cracked a motor mount? Iam lost or is this some type of safety measure built in?
Out Of Control!
Just curious how do you crack an engine mount? Is this because of when the torque kicks in or gear change or what? Is this a common thing? How does this get prevented from happening or you can't prevent it?? This is interesting.
thanks!
thanks!
Volvo V90 CC
The left mount on my E broke at around 42 k miles, dealer changed both under warranty, I've said this before, but here it goes again, this is what I was explained by the shop foreman:
Engine mounts are the weakest point on your car, they are built light and are supposed to easilly brake on an accident, let the engine fall and not hurt you, because of the way they are built they can brake after a while, but dealers are well aware of the issue and will replace at no cost.
I asked the foreman if driving the car hard will brake them or will expedite the braking process, he said it doesn't, they brake when they brake regardless of your driving habits. At least that's what I was told, I was satisfied with that explanation, if somebody is not satisfied with this explanation I suggest you talk it over with your service advisor.
BTW, how was that for a mature, useful and no smiles post??
Out Of Control!
That's a great explanation pochs. So i'm kind of worried. Reason is lets say you're at around 40,000 something miles and the engine mount breaks does that mean that your engine will just fall of with no warning or how would you be able to detect this?? This seems like a serious problem.
Volvo V90 CC
When you take off a little hard from a stand still you feel a hit (or something hit), then you know something's wrong, if both mounts brake I do belive the engine will fall, but one should hold it pretty good, I drove the car like that for a couple of days and drove it hard (not knowing what was wrong), when the shop foreman saw it was the mount he didn't let me drive the car and fixed it in two hours. So you will for sure feel it and you will have some safe time to get it fixed.
SLK 350 '05
woah....does this apply for the lesser E's as well?
that'd suck if you were driving around and suddenly...clunk..the AMG V8 is left on the road skidding...ouch..
Out Of Control!
E55, F550, S600 Ducati 999
Your engine will not fall out if both mounts break due to their design. Hard driving does effect the life of the mounts as they react to the torque of hard acceleration. When the engine mount breaks on my car it can be noticed by the exhaust system hitting the aluminium shield around the the steering shaft, which it appears to have done again
Both the front left and right engine mounts collapsed. My service advisor said my hard driving probably attributed to it, but hes cool about it, he knows that I regularily take her to the drag strip, and says they will probably go in another 40K miles.
Can wait for my engine mounts to break! If they never break then you have been driving your E55 like a girl! He-He!
Volvo V90 CC
And this car was not meant to be driven like that , no Sir!
Out Of Control!
Originally posted by pocholin
you just neither forget nor forgive!!!!
Volvo V90 CC
Originally posted by JamE55
Ok let me spell it out it's not meant to be beaten by high end cars! How's that? Were you thinking of something else?
1999 E55, 2005 525i
The engine mounts on MBs do not break they leak. The mounts have a type of oil inside. You know they not good when:
1. Vibtration when motor is idling.
2. Knocking of the exhaust on startup.
3. Knocking of the exhaust at a very low speed
4. Oil on the protective cover under the engine.
It is only more of an annoyance based on the above things happening. Aggressive driving does add to how quickly this happens in any car.
MikeC
E55
MikeC
E55
Originally posted by MikeC
The engine mounts on MBs do not break they leak. The mounts have a type of oil inside. MikeC E55
