GPS Antenna help needed please
06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
I am installing an Alpine Nav, my car didnt come with the original Command.
Can I tap into the roof mounted GPS antenna to connect to the Alpine , instead of running the Alpine antenna from scratch? and if so where would the wiring be? Any help is greatly appreciated. Thanks, Max
W203 slightly modified
What is the connector on the back of the Alpine unit ?
There is a whole range of adapters on eBay for one type of connector to another.
If you have tele-aid prewired then you already have a lot of GPS wiring in the car.
I have a 2000 CLK 430 factory, I have the same question as I will not like to add a GPS magnet antenna on my car... PS. My did not came with the Tele Aid... how can I tell
E55
E55
If you are taking it to a stereo installer, they should know where to put it so its hidden, if you are doing it yourself just test the signal with the gps antenna behind the deck or try to mount it closer to the top of the dash on the inside, worked on my old car.
Impressive info MR888!! i think for ever the roof antenna works direct for the GPS unit!!
But you are corret works with the gsm phone signal!
Thanks bud
Fabio Daniel
