LOUD Brake Squeel....
I hear about some anti-vibration's to solve this problem, they are original MB part number with "A 220 ... .. .." (i dont know thats works for our W210's, maybe someone can check that info) they are installed inside the piston calipers & solve this squeel! in the original package i see 4 antivibrations (maybe for the 4 pistons W220 calipers) someone see thats for our amg single calipers?
Fabio Daniel
Fabio Daniel
It is your rear brake pads, they are very low. Your fronts are also pretty worn probably (assuming they were changed at the same time).
Rear pads will always wear out faster on our AMGs b/c of traction control, the rear brakes are constantly kicking in to control all that torque under the hood so the rears wear out quick if you drive aggressively.
Upgrades your pads to either axxis or Hawk, both are good pads (and have alot less brake dust than the stock pads).
