gonna get headers...I have a few questions....
if you want go GREEN with the earth! leave your primarys
Fabio Daniel
. Be sure to take some videos of the car once done. If you haven't done high flow 2nd cats & crank pulley I recommend those as well in conjunction with the headers. They will significantly improve performance and work very well in conjunction with the headers.
~AMS~
I will take before during and after pics as well as dyno runs....let see how they do shall we....I am installing myself so I will be able to show everything first hand
Should sound good with no 2nd cats
. Install should be relatively simple, You may have to take out the plug wires & coils to have better access down there on the drivers side (it can be a bit tight). Do you have a lift? It is more difficult to install without a lift (although not impossible). If you have any technical questions feel free to email us at any time.
well got home from work today and there were my headers on the stoop....my initial impression are that they are very heavy duty....oem like in quality......thick flanges and tubing.....they are pretty small as far as I am used to(the last set of headers I did were B&B 1 3/4 in longtubes on a Dodge Viper) but they definitely look like they will work well.....and fit well.....I will keep everyone informed during the install
Looks so easy to install even a Nutless Monkey can do it
-Armani
We are glad you are satisfied with the quality. They are built to withstand pretty much anything you can throw at them and last the life of the vehicle, so only top quality thick materials are used to ensure they meet the demands of these AMG engines.
The headers are 1.75" OD (not 1.75" ID). If the header primaries were any larger you would start to harm torque. Remember, the stock exhaust ports are only 1.5" at the heads so you can only go so big. These are made for the optimal size for our cars and you cannot really go any bigger without starting to harm back pressure. They sure are an upgrade over the stock 1.4" primaries that's for sure
Look forward to hearing your impressions
. Shoot us an email if you need anything. Thanks~AMS~
Glad you like them. Told you that you wouldn't be disappointed. Remember ECU takes about 1 week to fully adapt so the sound & power should improve a bit more up to that point as well.
~AMS~
