Can someone blow my mind? Rear end spider gears welded into a posi?
Old Oct 24, 2009 | 07:11 PM
mandrewlt250r's Avatar
300sd 300td e55
I want a posi. Do u think the rear could handle the power and what are the chances of snapping my axle? Pros and cons?
Old Oct 24, 2009 | 07:44 PM
Fabio D's Avatar
210 55
You can.. but is not the way...
The 100% locked diff is only & stritictly used in a drag races. the welded spider gears (100% locked) made impossible drive the car in a wet seasons IT's IMPOSSIBLE or in your first little turn you go front & kill you by self. not speak about the parts stress (axle, tires, bolts, homocinetical joins)
Just... Don't do it... "go for Quaife 25-45 % locked LSD"
Fabio Daniel
Old Oct 25, 2009 | 11:13 PM
Max Hughes's Avatar
A locked diff will drag the inside tire when you turn and you'll lose the rear in the rain even at 5-10 mph.
Phantomgrip LSD blocks(like kleemann lsd blocks) are $500 and they have been done before in a E55 and my E320. You can change springs out and heaviest duty springs will land you over 50% lock up while the lightest come in at 20-30%.
Old Oct 26, 2009 | 05:26 AM
Silver Logic's Avatar
W210 E55 AMG
Fabio Daniel
Do they make a Quaife for a 1999 E55? All I see are for the the 2000-2002 models.
Old Oct 26, 2009 | 08:21 PM
Lawrence1's Avatar
2011 G55 + others
they should be the same.
Old Oct 26, 2009 | 09:08 PM
Fabio D's Avatar
210 55
Yha! it's the same 2.82 final drive for 98 to 02 i think! is the same diff
i recommend you if you use your car in a daily drive & wet streets or raining seasons go for a light locked % to not frie you tires & have a good traction (really the LSD is not very good for a wet streets cause you lose traction in one of the rear tyres when you turn) but is no bad in terms of performance & dry traction
Hope that help
Fabio Daniel
Old Oct 28, 2009 | 06:04 AM
W210 E55 AMG
Hope that help
Fabio Daniel
So would it be worth it to put the Quaife in our 210's or just leave them stock?
Old Oct 28, 2009 | 10:56 PM
Fabio D's Avatar
210 55
I dont invest my money in a LSD because i don't put my car in a 1/4 mile races, the LSD help your traction in a dry days, but in a wet days is not very helpfull.. for this reason Merceses/AMG not use LSD factory.. BMW M power use LSD in all cars.. the lock % affect very much the driveability sens (you can use by daily drive the 35% locked with no issues).. if you want & have the money, you can... but really i think in exhaust, headers, pulleys, BMC's & some chip tuned before think in a LSD
Just my point
Fabio Daniel
Old Oct 29, 2009 | 01:51 AM
W210 E55 AMG
Just my point
Fabio Daniel
Ok, I understand. Thanks. What are BMC's?
Old Oct 29, 2009 | 11:34 AM
pinoyk20's Avatar
99 model w210 e55 amg
air filter bro.
Old Oct 29, 2009 | 10:50 PM
Fabio D's Avatar
210 55
Originally Posted by pinoyk20
air filter bro.
1+
Are the best airfilters to me.. like K&N's (pretty same quality, i preffer BMC's because not have amunt of oil "factory oiled" than K&N's.. but the 2 brands have a very hi quality filters) just your choise,,
Fabio Danel
Old Oct 30, 2009 | 01:49 AM
W210 E55 AMG
Ok. Thanks guys.
pinoyk20,
How do you like your Green filters?
Old Oct 30, 2009 | 02:08 AM
pinoyk20's Avatar
so far so good bro. i think they sell BMC over at enkat at evangelista.
Old Oct 30, 2009 | 02:25 AM
W210 E55 AMG
Thanks. Will check it out.
Old Oct 30, 2009 | 09:58 PM
Fabio D's Avatar
210 55
Haahahahahahha good say bro, good say
I hear about some people with green airs, broken the black silicon sealant, but really i think this happen with a bad installation procedure.
Check this thread, have a good info & experiences: https://mbworld.org/forums/w211-amg/...u-check-2.html
Take care
Fabio Daniel
