is it possible to convert e55 to stick shift?
Old Mar 14, 2010 | 01:15 PM
dior's Avatar
2002 e55
is it possible to convert a 210 e55 to stick, maybe using a t56 with a custom adapter plate?
reprogram the me ecu to not see an automatic trans?
Old Mar 14, 2010 | 01:36 PM
45acp's Avatar
BMW
i don't know where you're located, but i think in the UK w210 6's had an option for a manual trans. if somehow you could adapt it to the v8 block with the correct bolt pattern bellhousing, i don't see how mechanically i couldn't be done (using all the clutch linkages and pedals from the manual car). but the electronics of it all, thats another story...
Old Mar 14, 2010 | 03:03 PM
mikekuriger's Avatar
2010 C63
anything is possible.
Old Mar 14, 2010 | 04:50 PM
Eurosport's Avatar
monowiper
yup e270D and e300D all had option for manual tranny. you find them mostly on e270 though since it's more stripped down car(no leather...)
i've driven one but i can tell you it sucks, it's not a sporty type shifting, more like a boat...
Old Mar 14, 2010 | 05:25 PM
tc1728's Avatar
with enough money, you can make it fly. TC
Old Mar 14, 2010 | 09:08 PM
saintz's Avatar
GL450
The issue will probably be in the electronics. The computer will be looking for shift points and a lot of other things and won't be seeing them. Also, there's an issue of whether the manually tranny you find can support the almost 400 lbs ft torque the motor produces, which isn't a crazy amount, but is more than a lot of stock manual trannys are rated for.
Old Mar 14, 2010 | 09:21 PM
tmaguire's Avatar
2005 CL55 AMG, 2004 S430 4matic, 1988 560SL, PRIOR: 2000 E430 4matic, 1994 E320 Coupe, 1999 C43 AMG
An SL500 transmission will fit to an E55/E430/C43 motor... However, the shift points ECU will still be a difficulty...
Old Mar 14, 2010 | 10:44 PM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
I think I heard Kleeman used to sell one,and it was alot of $$$$.
In the 80's they used to make manual trannies for V6and V8 MB's like the Hammer and other specialty built MB v8's in Europe.
Old Mar 15, 2010 | 12:00 AM
Esh's Avatar
Esh
E55
Short answer: if it's possible, it's going to be very expensive and you will have very limited support for answers if things go wrong.
Old Mar 15, 2010 | 11:04 PM
ProjectC55's Avatar
Old Mar 15, 2010 | 11:45 PM
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
Honestly, the stock OEM transmission really starts to come alive when you put more power through it. In stock form it may seem kind of slushy, but it does a pretty impressive job of putting the power down if you tune the car properly. If it really bothers you that much you can always do Tranny ECU upgrade.
the manual swap will probably cost half the value of the car, if not more... its not really worth it, you are better off spending that money on performance mods (or just selling it and getting another car).
Keep it auto and enjoy it for what it is.
Old Mar 16, 2010 | 11:32 AM
jordanst2's Avatar
1999 e55 (past), 2002 CLK55 (past), 2004 E55 (present), 2008 Z06
Save your money and buy an e39 m5
Old Mar 16, 2010 | 05:11 PM
ProjectC55's Avatar
LOL! I dont think anyone would give a better ans than that!
