Where can i get OEM carbon fiber look cover that goes over doors
If anyone has any extras or knows where i can buy new ones please let me know
Thanks you!!!
-Flo
You could order new pillar covers though. The carbon fiber wrap might have problems staying flat over a rusty surface, even with good surface prep prior to wrapping.
Saw some pillar covers for sale here:http://www.mercedesbenzwheel.com/mer...m-exterior-44/
I'm sure there are others as well.
Hope this helps.
Hope this helps.
thanks , i have a set of carbon fiber tape ons .. am actually looking for the whole pillar ..
That setup in the pic actually looks very clean and professional ..
Will put the tape ones on tomorrow just to see what they look like i got them cheap anyways ..
btw: how much did that wrap cost ?
thanks
The wrap went all the way around the pillar covers to the back, making for a seamless install.
The wrap went all the way around the pillar covers to the back, making for a seamless install.my local shop wants $140 to wrap all four pillars .. Thats effing krazy lmao wish your shop was near by lol
thanks
Joel@konicek.com
1. Roll window down. Remember to switch the key back to the OFF position after you do.
2. Pull out the section of rubber moulding from the area where it joins the B-pillar covers.
3. Unscrew the two locking screws on the B-pillar.
4. Using a plastic wedge (or a wrapped flathead screwdriver) pop out the bottom trim on the window. Prior to reinstalling this trim you might want to use some elbow grease to remove any accumulated gunk and hard water marks that are visible on the paint. This is especially glaring on dark colored cars.
5. Lift the side where the locking screws are located and at the same time slide towards the opposite direction as the pillar covers are clipped into the door frame. The pillar covers should come off easily. Take care not to lose the white plastic clips that helps keep the rubber moulding in place. (At least that's what I think it does).
Installation is the opposite of removal. Make sure you clip the ENTIRE pillar cover to the door frame before installing the screws. You will know if you have because the pillars will fit flush with the doors closed.
I'm sorry for the celfone pics. And don't mind the apparent inconsistency (i.e., removing a pillar cover that's already in carbon fiber, and popping window trims when the pillar cover is already out) in the pics vis-a-vis the steps being described. I took the pics after everything was done. The description on the pics are to highlight the important areas.
At this point in time if your rear window regulator hasn't gone kaput on you yet, you might want to prepare for that eventuality when you roll down the window.
Please don't bill me for any mishaps.
