Just lowered it.
Old Mar 14, 2011 | 12:49 AM
mtnhouse's Avatar
02 E55
Just lowered it.
I bought an H&R springs to lower my car. After lowering my car I see 2 problems. First problem the front did not drop that much, I know I need to wait for a few days until it settles but if you compare how much the back drop its a big difference. Second problem is the back passenger side is scraping. When the car bounce it scrapes but just the back passenger side only. I just dont get why the right side is scraping. Check out the pictures and my bro's 124
Attached Thumbnails Just lowered it.-img_9518.jpg   Just lowered it.-img_9514.jpg
Old Mar 14, 2011 | 12:59 AM
desired_speeds's Avatar
2007 SL55 AMG
are you sure you installed the springs correctly?
Old Mar 14, 2011 | 01:03 AM
JamE55's Avatar
Out Of Control!
Spring Pads
You're probably still using the stock spring pads upfront which are # 3. Change that to spring psd # 1 which is the lowest setting and that should solve your problem.
Old Mar 14, 2011 | 01:10 AM
2007 SL55 AMG
that's weird though, the front is like stock height. I was debating over vogtlands and H&R today. When you get this figured out, I'd like to see the finished results!
Old Mar 14, 2011 | 01:24 AM
bnzuovr's Avatar
2004 W211 E55K, GL550
i used H&R's and my car sat great both front and rear but the spring pads like they said should be changed to 1 spring pad also not to sound like a *** but check the springs maybe they were installed wrong. As far your rear most likey your shocks are worn if you have never changed them could be causing the rubbing hope that helps.
Old Mar 14, 2011 | 07:00 AM
DRBC43AMG's Avatar
From: CH = Land of mountains, cheese, chocolate and watches
After checking what has been said previously, get a suspension alignement check done. That could/should solve the rubbing issue. What I don't understand, is the rubbing on both sides on the rear or only on one side?
Old Mar 14, 2011 | 03:19 PM
mtnhouse's Avatar
02 E55
Thanks for all the advice. I think JamE55 is right I need to change the pads in the front. I think it got installed correctly but I will check it again just to make sure. I hope alignment will fix the scraping on the right. I will update you guys once I fix this problems
Old Mar 14, 2011 | 09:21 PM
armaniE55's Avatar
2012 CLS63 AMG
That's an easy one- your shock in the rear is shot.. How many miles? Also take a look at the tire on the outerside to make sure it's not rubbing on the fender our cars come with the fenders already rolled. I would never recommend doing the springs alone it's always best to do springs/shocks at the same time and springs pads to lower even more. I went with spring pads#1 but it was just toooooo low and went back to factory spring pads #3 but still having a nice stance. It really depends on the spring/combo.
GL
btw your bro's benzo is slammed
Armani~
https://mbworld.org/forums/w210-amg/...rims-pics.html
Pic attached with my drop
Attached Thumbnails Just lowered it.-cimg2261.jpg   Just lowered it.-cimg2263.jpg
Old Mar 14, 2011 | 09:56 PM
mtnhouse's Avatar
02 E55
@ Armani
The car has 74k I just bought the car a month ago and it came with a bilstein shocks. I will get the shock check if it still good. Is the pads and shims the same? Did you change all pads in your car? My bro said I need to change the pads in the front to a thiner one. Can you buy the pads at the dealership?
Your car looks great! When you have 3 or 4 passengers in your car does it rub?
Old Mar 15, 2011 | 12:10 AM
2007 SL55 AMG
GL
Armani~
your sig says eibachs but your said you have H&R in the linked thread. which springs are you actually using?
Old Mar 15, 2011 | 04:52 AM
DRBC43AMG's Avatar
@ Armani
Pads can be purchased at the dealer and at reasonable prices too
Old Mar 15, 2011 | 04:32 PM
mfletch69's Avatar
1999 E55
is there a noticable drop if you just stick with the stock springs and go to #1 pads?
Old Mar 15, 2011 | 07:03 PM
cudaized's Avatar
2002 E55 AMG Obsidian Black with Charcoal
I was just thinking the same thing....
What is the difference in thickness of the #3 and #1 pads? Anyone have a comparison picture?
Old Mar 15, 2011 | 07:35 PM
Viet_Amg408's Avatar
Pinto
that look out of perportion
i would go with #1 pads...give you lowest setup w/ sport spring..
if you want even more hardcore slam.. remove the pads all
btw. google.com type in E55 H&r sport and #1 pads
Old Mar 15, 2011 | 08:33 PM
w210e55k's Avatar
2001 e55 kleemann
#1 pad= 5mm
#3 pad= 15mm thickness
Old Mar 15, 2011 | 11:07 PM
armaniE55's Avatar
2012 CLS63 AMG
Thumbs up
@ Armani
Thanks! pads/shimes yes at first I wanted it a little lower but number one pads/shimes slammed my car, Peter a member here had number 3 pads that were sitting in his garaged. Shipped them to me and my current set up is stock again which happen to be number 3 pads. Dealer sells them for around $20
No rubbing and I've had about 5 in the back before with 2 in the front
Eibach Pro with Bilstein HD Love it!!!
Armani
Old Mar 15, 2011 | 11:08 PM
armaniE55's Avatar
2012 CLS63 AMG
Thumbs up
Good call
to confirm
Old Mar 15, 2011 | 11:14 PM
armaniE55's Avatar
2012 CLS63 AMG
It really depends on the set up- as you can see my pic above my stance I think is nice (#3 pads) Eibach Pro with Bilstein HD but when I had the #1 pads it was really slammed and that was with all 4 new shocks. Older shocks will dip a tad.
Armani
