Took me e55 to a drag strip, crapy times
I did 2 runs without front o2s plugged in, and rest with them in, didn't seem to make ay differance
70 degree weather , 1000ft elevation
Only was able to get 5 runs in that evening and 2 of them had horrible wheel spin of the line and messed up the times, 3 runs lunches were somewhat decent, although i might need stickier tires
results are pretty disappointing: best run was 14sec flat with 101mph trap and 2,20 sec 60ft
two other runs were also 14 flat with 100 trap speed and 2.30 sec 60 ft times
for comparison, my friends 335i run best of 12.53 1/4 with 110mph trap and 1.9 60 ft times,, also a stock charger srt8 did 13.66 1/4 mile, and charger hemi did 14.9
Track prep is a big factor, but it sounds like your friends are cutting good 60' so time to practice and check cond of tires, air pressure optimization, etc.....
GL.
GL.
Do you think its really possible to go down to 1.8 on these cars??
ohh and elevation is close to 1400ft instead of 1000
no way that none sc or nitroed e55 will do 12.5 when most guys are closer to 14
