Pressure in fuel tank
1999 E55 AMG
Just wondering if it's normal to have a bit of pressure behind the fuel tank cap?
Every time I fill up there's a fair amount of pressure behind the cap.
00 C200 & 00 C55 & 06 SLK55
You may have a clogged hoses or bad "purge valve" or bad check valve on the "constant charcoal filter".....!!
https://mbworld.org/forums/c36-amg-c...-detected.html
https://mbworld.org/forums/c36-amg-c...al-filter.html
ZAYED,,
ZAYED,,
Your Welcome,,
I'm not sure about the Australian version,
U.S version comes with a different shape with a Vapor valve, but EURO/Japan comes with-out Vapor valve,
and they sharing the same # with a Purge valve,,
you should check, what’s the spec. of Charcoal filter you have....,,
A) U.S. Charcoal filter: "210 470 08 59" or "210 470 13 59"
![Pressure in fuel tank-charcoal-filter.-u.s.jpg](https://mbworld.org/forums/attachments/w210-amg/256101d1542238905t-pressure-fuel-tank-charcoal-filter.-u.s.jpg)
B) EURO/Japan Charcoal filter: "210 470 03 59" or "210 470 04 59" or "210 470 10 59"
![Name: Charcoal filter. Euro.jpg
Size: 5.2 KB](https://mbworld.org/forums/attachments/w210-amg/256102d1364489559-pressure-fuel-tank-charcoal-filter.-euro.jpg)
C) Vapor valve: "000 476 30 32"
D) Purge valve: "000 470 15 93" or "000 470 35 93"
![Pressure in fuel tank-purge-valve.jpg](https://mbworld.org/forums/attachments/w210-amg/256104d1542238905t-pressure-fuel-tank-purge-valve.jpg)
ZAYED,,
![Name: vapor valve...jpg
Size: 17.8 KB](https://mbworld.org/forums/attachments/w210-amg/256103d1364489559-pressure-fuel-tank-vapor-valve...jpg)
ZAYED,,
1999 E55 AMG
Ok, great, thanks again.
Just out of interest, would there be any fault codes if any of these items failed?
I haven't got a reader yet, so interested in any suggestions
Cheers
Cheers
There are many CEL #s, such as: (P0440/P0441/P0442/P0443/P0446/P0450/P0455/P0460),
all those codes related to the Fuel & Evap leaks or malfunction system.....
ZAYED,,
ZAYED,,
