Help me to upgrade my car (monster) E55 AMG 1999
Old Jul 16, 2014 | 10:50 PM
e55 abdooo17's Avatar
E55 amg w210 1999
I measured it 3 inches diameter and
Eisenmann Exhaust pipe is 2.5 inches
Old Jul 16, 2014 | 11:41 PM
snooozie's Avatar
86 190D (Exported to the Nerderlands), 87 300TD (Sold), 82 Ford F150 3spd, 99 E300D (RIP), 02 E55
3 inches....wow, you might have to change all your mid and back pipes to 3 inches
Old Jul 17, 2014 | 12:33 AM
Need4Speed's Avatar
Former Vendor of MBWorld
2018 C63S
I highly recommend lighter wheels
HRE
ADV1
Niche monotek series
I carry all the lightweight forged wheels so i can tell you what works what doesn't.
As much as you put into the motor if you dont have lighter wheels it kills the purpose
Old Jul 17, 2014 | 01:25 AM
E55 amg w210 1999
Size slots Clement Headers and Down Pipe
no need for 3in med pipe 2.5 is inof(As said by Fabio) let the images speak for heders Size
I own this rim now18 the first owner bought her I think she's good now I think I am trying to faind rims 19 you can put some suggestions and if possible some pictures (let the images speak)
Old Jul 17, 2014 | 01:37 AM
snooozie's Avatar
HRE
ADV1
What light wheels you recommend in the 19's?
Old Jul 17, 2014 | 01:41 AM
snooozie's Avatar
ok, the downpipes connect to the mid pipes in the Kleemanns, I forgot..so 2.5" on the back pipes are just fine.
Old Jul 17, 2014 | 02:43 AM
  #32
Need4Speed's Avatar
2018 C63S
Depends on what you are after as well as price range
Niche makes an amazing light weight series from their Monotek series
pricing is on point and quality is superb made in the USA here in California.
adv1 and HRE are also very well and you cannot go wrong with those either.
Typically a 5 spoke design would be the best choice as there is less spokes which means less material which can save up to a additional .5 to 1 pound
shooting you a pm with more details
Old Jul 17, 2014 | 01:35 PM
  #33
ML63 AMG's Avatar
CL63 AMG
Forgestar wheels are lightest for the money and they have forged barrels. I run them on every car I buy.
Also, 2piece brake rotors help shed more weight too
Old Jul 18, 2014 | 07:58 PM
  #34
RacingBrake's Avatar
CLS550
Weight Redction
If your looking for light weight high performance two piece rotors,
stop at RacingBrake.
Front E55 AMG W210 Two Piece Rotors
Our two piece rotors are uniquely designed with our patented center mount, open slot, and convergent vane designs. All meant to improve cooling and performance.
to learn more about our advantages click below
RB two piece rotor features
OE One-piece 22.2 lbs.
RB Two-piece 17.9 lbs.
Weight Savings: 4.3 lbs each corner.
Check out some of the reviews posted by other MB owners:
Racing Brake makes me happy
World's First: RacingBrake 2-Piece Brake Rotors ...
The Ultimate Rotating & Unspring Mass Reduction Thread ...
E63 Front Rotor Replacement DIY - RacingBrake
https://mbworld.org/forums/sl-class-...squealing.html
Old Jul 18, 2014 | 10:34 PM
  #35
snooozie's Avatar
Hi,
Can you tell me the difference on the rotor surface finish and also do you have any pictures on the different rotor surface...the website only show a rotor..
Rotor Surface Finish
Open Slot
Drilled & Slotted
Straight Slot
Old Jul 21, 2014 | 11:39 AM
  #36
CLS550
Hi,
Open Slot
Drilled & Slotted
Straight Slot
All our two piece rotors feature our patented "Open Slot" surface design.
Open slot has the advantages of both drilled and slotted rotors. They increase the cooling area, retain more friction surface,
relieve thermal stress and allow the disc to expand and contract to prevent cracking or warping. They are also self cleaning and reduce brake pad dust build up.
Old Jul 21, 2014 | 02:05 PM
  #37
E55 amg w210 1999
Some images during installation. Note During the installation Headers next to the driver who ran into some difficulties I had to steer the car to the mechanic because of steering column.
There are some pictures about the quad pipe exhaust installed in my car from firest oner I think that in a bad way to install and you can get an idea of their work better
Note: during the decoding old Headers discovered that the nuts and bolts are made of copper with the knowledge that all most cars made ​​of iron, and this makes them not subject to rust over time excellent movement from Mercedes in e55 w210
Old Jul 21, 2014 | 02:28 PM
  #38
snooozie's Avatar
Just make sure you turn the steering and also make sure the heat shield does not hit the downpipes on hard acceleration with the Kleemanns. Best of luck to you on your install and hope everything works out. The Eisemann race exhaust will sound so awesome in the car
Old Aug 3, 2014 | 05:36 PM
  #39
E55 amg w210 1999
Been mounting
Hello everyone and thank you for your co-operation project with me in my car
i inestal heders +xpaip+exhost Sound very high feel it inside the car and feel everything vibrate inside the car sound wild i but
(Bottle Style) Resonators from vibrant (Part No: 17930 Description: Large Diameter Bottle Style Resonator, 2.5" inlet/outlet x 18" long .The man who advised me to putting Resonator is Ahmed Solfab from vividracing thanks very much ahmed treated him on the high-end and upscale style and useful advice
During installation I need some costem pipes to conect it to the mufler
after kleemann daown pipe I was hoping to put x pipe
First vibrant Resonator Second but i cant Because of the narrow space beneath the car
Some images and Video during installation and after
note : i need to cut the x pipe frome summit .
Old Aug 3, 2014 | 07:45 PM
  #40
E55 amg w210 1999
exhost saund
http://www.youtube.com/watch?v=uQ1IW...ature=youtu.be
