Shimmey at 50kmph not in the steering wheel!
Old Jun 23, 2015 | 07:23 PM
Frank N Sense's Avatar
E55AMG 2000 E55 AMG 1921 Ford T Speedster
Hello.
Around 5okmph and on the smoothest just paved road here- Yes I can't believe it they just paved part of the moon here after the worst year of cratering ever- I have a slight shimmy and you can't feel it on the steering wheel but in the chassis itself and then goe's away around 60kmph.
I figure with hitting so many awful potholes perhaps a rear mag is slightly bent. Otherwise, why wouldn't I feel it in the wheel?
Your opinions please.
Thanks.
Old Jun 23, 2015 | 07:39 PM
Jan AMG's Avatar
The best or nothing
Hi,
what's your mileage? Could be a driveshaft even at low 10's after 15 years. Check bearings, bushing, flex disc..
Found this online, maybe it helps.
#120 is the "rubber boot bearing", P/N 211 410 01 81
#130 is the bearing, P/N 008 981 43 25
#140 is the boot, P/N 202 411 04 97
Old Jun 23, 2015 | 07:52 PM
Jan AMG's Avatar
The best or nothing
One more thing, check your (front) shocks and engine / tranny / diff mounts.
Old Jun 23, 2015 | 07:54 PM
Originally Posted by Armadillo888
Hi,
Hi and Thanks for responding with the info.
I could be wrong but there isn't any noise whatsoever coming from the drive shaft in any way.
I've owned to 928's and understand torque tube issues related with driveshaft issues.
Flex disc. is another story.
These are just my hunches nothing is factual and I will keep your observations in my head.
Thank You..again.
Much.
Old Jun 23, 2015 | 07:57 PM
Whoops...163000km on the clock.
Thanks again friend.
Much appreciated.
Question: Do you do your own work?
Regards.
Old Jun 23, 2015 | 08:02 PM
Another note: My tires were over inflated. There was a hardly perceptible shimmy at all!
I deflated the tires to 32psi because the ride was too harsh. The ride is more supple but this shimmy showed it's dance.
Old Jun 24, 2015 | 06:04 AM
Jan AMG's Avatar
The best or nothing
Much appreciated.
Regards.
I have my indy do the work as I don't have a proper garage with tools myself, only parking spots. I try to learn about everything and at least order parts myself or with him. I used to visit MB and pay exorbitant prices with my W221 and W126 but then I realized these guys don't know what they were doing when I saw their results (I cross checked with official service manuals).
I think owning a Merc is either:
- Buy a brand new one and drive it for 1-2-3 years, then replace it with a brand new one again. This is quite costly though, you get the biggest depreciation.
- Buy a youngtimer or older model and learn everything about it. Do your research and keep the car in top shape. Use only original parts. Then it drives like a Merc. This is the best option, costs 1/10-1/5 and brings a lot of joy. Takes a lot of time though. The good thing is you get to drive what you want, you can afford to own not 1-2 but 5 cars and people do not envy you the latest model.
Jan AMG's Avatar
The best or nothing
Where are you from? Post some pictures of your car.
Old Jun 25, 2015 | 02:25 PM
MBFanUSA's Avatar
2001 E55 AMG and 2012 GL450
Hi -
I just replied in another thread on what may be the same topic. Search in the general w210 forum for "off throttle vibration". (I'll see if I can figure out a thread / post number...)
Seems that often the root cause is rear subframe bearings, and can be remedied either by replacing them or by removing the differential mount shim (the latter being very easy).
Hope this helps...
Old Jun 25, 2015 | 02:33 PM
Jan AMG's Avatar
The best or nothing
Originally Posted by MBFanUSA
Hi -
Hope this helps...
Hi,
great. Do you happen to know part numbers?
Old Jun 25, 2015 | 10:37 PM
Hi and Thanks guys.
I was experimenting with tire pressures before the car was surprisingly quickly purchased!!
35psi all over and 45 on the passenger front tire almost negated any shimmy whatsoever.
Weird!
Anyway to sum up...I will be looking for another soon-a 2002 if I can find one.
You guys show much restraint...DON'T YOU WANT TO KNOW HOW MUCH I GOT FOR THE CAR!!??
Old Jun 28, 2015 | 10:16 PM
benzokirk's Avatar
Veteran: Air Force
2008 E63 AMG, 2018 VW Golf R
Actually, if you have some pics of the car before it was sold, I'm curious to see it. I read your post of the guys ogling it before buying it, it must've been a beauty! THEN I'd want to know how much you got for it...
Old Jun 28, 2015 | 11:29 PM
Hi..I'll try to post pictures. I may have a couple.The car was like a dark dolphin grey.
I got $12500 for it.
It was usually very clean and the interior was almost like new.
